20 Most Recent
Dell Inspiron 560S Desktop Computer (Intel Celeron 450 640GB4GB) (DDPHBA51) Questions & Answers
I have windows 7 and do not care for the way it
Ok - this can be done - step by step...
1. Control Panel\All Control Panel Items\Personalization\Window Color and Appearance
2. At bottom of that screen: Advanced Appearance Settings.
3. Top selection drop down - find Application Background.
4. Change that to a more agreeable color.
5. Save changes.
6. Enjoy a PC that you can look out without being blinded by the bright whites.
Cheers.
PS - Tested on my Windows 7 Home Premium.
CD-ROM not reading any data
Either the CD/DVD drive is bad or the driver software for the disc is bad. If you can boot from the CD/DVD it's probably software.
When i am going to boot my pc through usb (window 7 ultimate) it show disk read error.....
I can think of three likely problems and one unlikely problem.
1. Did you really burn the ISO image to the pen drive? Did you use software such as freeisoburner:
http://www.freeisoburner.com/to burn the ISO to the drive or did you just copy the ISO to the drive? If you just copied it, then the computer can't read the files
2. The USB drive may be broken. Have you tried burning the ISO to another flash drive or disk?
3. The copy of windows you downloaded wasn't the whole thing and there are missing files that once again, the computer can't read or find
4. Your USB ports on the computer is broken.
Connecting the wires from computer to screen
What exactly is the problem?Do you know the type of cable connection you have on the monitor, HDMI, PCI, PCI-E, VGA?The computer is rather old but it looks like it has one VGA and one HDMI connection, all you need to do is use a cable that matches the connection type on the PC to the type on the monitor. You can get cables that have the same connections on both ends or you can get cables that use different connector types on each end or use an adapter. It's rather simple to find whatever cable or adapter you need but we need to know what connector the monitor has.
Burred smile coming inside the CPU
Hi,I believe you are asking about a burned smell coming from your PC case.Firstly check your power supply as this is where the high voltage power is and therefor the most likely source of the burn smell.Best wishes,Graemevm
