20 Most Recent Systemax SYX Crossfire X58 Gamer Intel Core i7930 28 GHz genuine Windows 7 Home Premium 64 Bit 12GB (SYX1040) PC Desktop Questions & Answers
Change boot order bios
Go into set up usually f2 on start up, you will find boot configuration with instructions
3/27/2017 9:59:28 PM • Systemax SYX... • Answered on Mar 27, 2017
3answers
The computer won't boot Windows
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
4/21/2011 6:11:56 AM • Systemax SYX... • Answered on Apr 21, 2011
0answers
What is the maximum memory supported for my Systemax laptop model number 104787148
I have searched and I don't think that is the right model number.
6/29/2017 6:34:28 AM • Systemax... • Answered on Jun 29, 2017
Keyboard will not connect
Do light come on when you boot up computer ?
3/27/2017 9:58:28 PM • Systemax... • Answered on Mar 27, 2017
Where do i find systemax el81 drivers?
driverguide.com or download slim drivers and run program
3/27/2017 9:56:12 PM • Systemax... • Answered on Mar 27, 2017
Need power switch etc for Systemax Venture model# SYX-DG4!MJ
ebay and amazon would be two possible places also your local computer shop
6/27/2016 9:49:01 AM • Systemax... • Answered on Jun 27, 2016
Systemax desktop boot diskette
do you need a boot disk? do you have one but it doesn't boot? if you can provide with more information about your situation.
11/9/2015 2:45:41 AM • Systemax... • Answered on Nov 09, 2015
Owners manual for STX:G41M-P33
http://www.msi.com/product/mb/G41M-P33.html#hero-overview Here you go.. Register your product so you can get the manual.
9/7/2015 4:49:06 PM • Systemax... • Answered on Sep 07, 2015
2answers
What is the maximum memory supported for my Systemax laptop model number 255113 right now I'm running 1 gig thank you very much
you will need your laptop serial number got to this link http://www.supportforyourpc.com/ enter your serial number it may state max allowed memory if not find out what motherboard is installed and google the motherboard add specifacations to the search and you should be able to find out the max memory allowed
6/25/2015 5:19:16 PM • Systemax... • Answered on Jun 25, 2015
How do i get wifi on my laptop?
On laptops without a dedicated WIFI power button, usually the wifi is turned on via a Hot Key. Look at the FUNCTION keys on the laptop. Are there any BLUE symbols there? If so, these are Hot Keys. One of them should look like an antenna (or a magic wand!). Press and hold the FN keys (down next to the WINDOWS key), and press the Hot Key. These keys work on a toggle-on, toggle-off basis. Once is it on, do it again to turn it off. Once you've tried this, look for the WIFI indicator light to be lit.
3/2/2015 5:04:47 AM • Systemax... • Answered on Mar 02, 2015
Model AL-8360BTX serial No 106938626,[ put a video card a while ago and add Rams].Problem: doesn't stay on / screen said "no signal". One Beep/ I change power supply going from 350w to 650w .
Does the graphics card (GPU) require it's own power connection? Many GPUs do require an additional power supply beyond the PCIe slot itself. If you are uncertain, check the manual or physically check the card. The power inlet will be a square or rectangle with four to six slots (higher-end cards may have two of these). Most modern power supplies (PSUs) will include a connection for these.
1/2/2015 9:36:47 PM • Systemax... • Answered on Jan 02, 2015
Where can i find specs for my systemax venture desktop
there are specs inside the case, on the bottom, for my systemax venture. there is also a serial number on the back of the tower, on the outside; however, i believe that the systemax desktops were actually assembled by tiger direct.com.
12/28/2014 10:42:34 PM • Systemax... • Answered on Dec 28, 2014
How do you hook up dragon speaking device
use the front panel audio socket 20.December.2014
12/20/2014 4:46:31 PM • Systemax... • Answered on Dec 20, 2014
I have a Windows Server 2003 system on a old Dell desktop. I want to move it (hard drives) to a Systemax Venture.
You need an IDE controller board to boot from. The SATA drives have not system on it only data, so it cannot boot from these drives.
10/14/2014 10:05:15 PM • Systemax... • Answered on Oct 14, 2014
What is red light in tower for?
The light in the tower indicates power is going to the motherboard. It is helpful since it is never a good idea to mess with a powered motherboard.
7/31/2014 7:06:52 PM • Systemax... • Answered on Jul 31, 2014
What is max. ram for a systemax syx-p8h61-mlx2 / serial,107477756
2 x DIMM, Max. 16GB, DDR3 1333/1066 Hz Non-ECC, Un-buffered Memory
7/24/2014 7:20:27 PM • Systemax... • Answered on Jul 24, 2014
Can I change from Windows XP to Windows 8 on my current Systemax hard drive
Yes you can upgrade from Windows XP to Windows 8, depending of the age and specs of your computer it might run slow, you will need a minimum of 2Gb of memory to run Windows 8 at a decent pace.
7/21/2014 4:19:28 PM • Systemax... • Answered on Jul 21, 2014
Systemax SYX Crossfire X58 Gamer Intel Core i7930 28 GHz genuine Windows 7 Home Premium 64 Bit 12GB (SYX1040) PC Desktop Logo
2 questions posted
Top Systemax Computers & Internet Experts
Ngoro
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Systemax Computers & Internet
Most Popular Question
computer boot windows
  • Computers & Internet
