Hi you could have a clogged drain pump or obstruction in it. Remove the lower bottom cover. Have a container or towels to catch water. Removed the drain cover by turning counter clock wise. Sometimes you have to remove the pump to fully and clean. You also need to plug the washer into another outlet. If possible use an extension cord use the extension for test only.
F09 error is a overflow error and is displayed when the
overflow contact on the pressure switch is closed for more then 60seconds.
First make sure that the drain pump assembly located inside the lower access
panel is not clogged then check the wire harness connections to the drain pump,
pressure switch and the central control unit. If everything is fine then the
pressure switch should be replaced. Hope this helps...please post back for
further assistance.
USE THE COMMON SENSE, FIX IT. God bless youPower from the house
Check to see whether there's power getting to the dryer. Is it plugged
in? Check for blown fuses or tripped circuit breakers--your dryer uses
two fuses or circuit breakers. The dryer could tumble but not heat if
only one of the two fuses is blown. If you have circuit breakers, one of
the two circuit breakers can trip, even if the two for the dryer are
connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit
breaker or blow a fuse. The heating element is simply a long coil of
special wire. You can check it for continuity with an ohm meter. No
continuity means the element is bad and you need to replace it. The
proper ohm reading can be found in the service manual or sometimes on
the tech sheet located somewhere on your dryer (9- 13 ohms is a common
reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover.
The fuse--which is about an inch long--is usually embedded in black
resin and mounted in a white plastic housing They are also round and
made of metal and plastic. The thermistor is located on the blower
housing usually. If any of the fuses do not have continuity replace it.
Check for continuity if none replace, But before replacing check for
obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at
the dryer, to burn and break its connection. Because the dryer can still
tumble with partial power, the connection may be only partially
defective. Check all connections, make sure they are tight. Loose
connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
According to the manufacturer, the error means the door could not lock. Check the door for obstructions when you close. To remove error, reboot the washer.
