20 Most Recent
Orion FTDV2004 20 in. TV/VCR/DVD Combo Questions & Answers
I have an Orien FTDV2004A tv/vcr/dvd combo. I was
HelloJust unplug the TV from AC mains wall socket, and replug into after 5 minutes or so. This should reset the set to its factory settings. If it does not help you, just take out the disc inside, and insert an other one. See whether it reads it or not. If not, the set need service. Especially service to its DVD mechanical side. OK.
Have had digital installed and cannot get tv to work through digital. Any advice?
HelloThei Orion model Tv is not equipped with a digital tuner inside. There is only an analogue tuner fitted and only analogue channels can be received by this set. To get digital channels, you have to buy one settop box, which can convert digital signals to analogue signals. In short, a Digital to Analogue Converter should be bought, if you want to get digital channels. OK.
I have an Orion FTDV2004A tv/vcr/dvd combo. I was
HelloJust power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
How to take hearing impared writing off
Hi and welcome to FixYa,
On the original remote of this TV, this would be 'Closed Caption' feature and could be disabled in the MENU/Settings.
Good luck and thank you for using FixYa.
Need the code to play
It does not appear that this unit can be region unlocked... Are you positive that it can? I am quite certain it can not. I am sorry about that.
Vcr is eating the tapes
THE VCR NEEDS REPAIRING.THE REASON WHY YOUR TAPE IS EATEN THE TAPE PATH NEEDS RE- ALIGHNMENT AND LUBICATED AS THE HEAT FROM THE TV WOULD OF DRIED THIS OUT.
Only 5 channels
Try purchasing one of the cheap "All in One" universal remote control handsets.
