20 Most Recent
Orion VR213 VHS VCR Questions & Answers
Vcr keeps kicking tape back out
Something is stopping the tape from fully loading.Do you have young children? Very often the kids will "post" something through the cassette flap. Remove the top cover & look inside the mechanism for any unusual object or its also possible something in the tape alignment path has broken which will also be lying inside.
Retune a video player
do you still have your remote? You may need it to go to menu - setup - auto tune, that may help you
How to set the vcr
- The link is to the manual for your VCR. If you reference Please reference pages 17- 23 for the steps for a timed recording. http://www.mediafire.com/?l1ryq534eh3w1a6
- The link is a PDF you download to your PC for free.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
HOW TO PROGRAM MY VHS
Hi.
--make sure you have a blank tape in the VCR...
--GO TO MENU..
--your clock should show the real time..Correct it if it is not..
--select TIMER
--than select and adjust` start time` and `duration` of recording..and ` channel to be recorded `
--SAVE it..
--Turn off the video .
--you must see a small CLOCK/TIMER ICON on the LCD panel which proves that you did it..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
How can i fast foreward
If you are watching a tape, simply use the FF button to skip forward until you see that the commercial is over, and then press PLAY to resume playing.
If you are watching a live TV program, the short answer is - you cannot. You need a PVR or TIVO or such device to be able to do that - and even then you have to be time shifted back at least the duration of the commercial you want to skip first!
I need to set a 'One For All' Remote
One For All remote manuals and code lists are available here:
http://www.oneforall.com/support/manual . Which specific remote do you have?
Most of the One-For-All remotes use a 4 digit code. The only one, URC-2005, that has 3 digit codes (of the ones I located) gives Orion VCR codes of 036, 088, 121, 208, 209 .
Note: remotes are limited to having codes for devices released at least 6 months before the remote was programmed. If your VCR is newer than the remote, you may need a new remote.
I hope this helps.
The unit doesn't respond to
sounds like you activated the built in surge protector . you need to unplug it for about 10 minutes to reset the surge protector let me know if this works for you
I am unable to change the recording speed. I go
Hi,you should have on your remote a button call rec speed or speed
or on the front panel behind the door...some vcr got only two speed choice slp and sp mode when you find the button speed pres rec and pause then change the speed you need..
hope that will help you
regards Alan
