20 Most Recent
Canonical Ltd. Ubuntu 606 LTS Dapper Drake (AMD64 Edition) [DVD] Linux Operating System Questions & Answers
I need drivers
Ubuntu already contains almost all drivers that are available for Linux, and your motherboard is fairly old and generic. You need to specify what component you need drivers for.
When surfing the net my pointer disappears?
This is a common problem with the unknown monitor. You can fix it manually. Open System Settings > Displays. In the Displays window, you will see an Unknown monitor. Click it and disable it. to remove this monitor follow this link
http://askubuntu.com/a/365017/34385
Sis m672mx
it has on-board graphics,15.4 Widescreen, Screen Type - WXGA ,Screen Resolution 1280 x 800 is default.....
Installing a .zip file in ubuntu
The easiest method is to open a terminal window, change directory to where the ZIP file is located and type:unzip <filename>.zipThis will unzip the files into the current directory.
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
