20 Most Recent
Canonical Ltd. Edubuntu 606 LTS Dapper Drake (AMD 64 Edition) [CD] Linux Operating Syst Questions & Answers
I need drivers
Ubuntu already contains almost all drivers that are available for Linux, and your motherboard is fairly old and generic. You need to specify what component you need drivers for.
When surfing the net my pointer disappears?
This is a common problem with the unknown monitor. You can fix it manually. Open System Settings > Displays. In the Displays window, you will see an Unknown monitor. Click it and disable it. to remove this monitor follow this link
http://askubuntu.com/a/365017/34385
Sis m672mx
it has on-board graphics,15.4 Widescreen, Screen Type - WXGA ,Screen Resolution 1280 x 800 is default.....
Installing a .zip file in ubuntu
The easiest method is to open a terminal window, change directory to where the ZIP file is located and type:unzip <filename>.zipThis will unzip the files into the current directory.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
