20 Most Recent
Nintendo Pokemon SoulSilver for DS Questions & Answers
How to Fix Error Code 52102
Click here to go to our Wireless Router Configuration page.
Use the drop-down box on the left to select, if available, your router manufacturer.
Click on your router's model number, if available.
Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
for more help visit
CBR Tech Solutions
How do I remove the Snorlax from the cave?
To move Snortlax go to lavender town and go to the radio tower and find that its not working properly. Than go to the power plant and find that somebody stole a pice. Than go to cealelean city and go to the gym and a team rocket grunt runs past you.Than go to route 24 and you will see him than he will hide between a couple. Than talk to him he will want to battle he won`t be strong so don`t worry.When you defeat him he will tell you where the pice is. Go get the pice than go back to the power plant and give it to a guy and it will start working again. Then go back to lavender town and go to the radio tower.Talk to everybody there someone will upgrade your raidio. Then go back to where Snortlax is and put your radio on poke flute. Hint don`t click on the four buttons just take the circle up and it will be on poke flute.Then talk to Snortlax he will wake up and want to battle. But be prepared he`s at level 50.It knows crunch,giga impact,block and another move but I forgot it. If you kill him battle the elite four and if you win he will return.I hope I helped.
How do I get the other Pokemon starter
if you chose totadile cyndiquil or chickorita as your starter and want to get the other ones then you could trade.if you mean from the other regions kanto and hoenn starters are avalible in professor oaks and the big building in saffron city once you complete the main parts of the story.to get them from sinnoh trade with pokemon pearl diamond or platinum. i hope this answers your question.
When I playgame on nintendo
You can try restarting your game by pressing start, select, up and B on the title screen.
If this doesn't work, you can contact nintendo, tell them your problem and ask for a new game. They should give you one in exchange for the old one.
Hope this helps
How to get all the legendary pokemon?
There are several walk-throughs and guides to obtaining all the legendary Pokemon in SoulSilver / HeartGold. Here is one that ought to take you step-by-step through the process:
http://www.psypokes.com/hgss/legendaries.php
Good luck :)
What cheat is it to get a master ball
if you want master ball you have to find it just like pokemon contest promo pokemon champion shipor in hte legendary pokemon caves because theres no cheat
I can't get online in
When you boot up the game, go to the Wifi settings. Double check that everything is put in correctly. Sometimes you need to put in your IP address too.
My son has Soul Silver and has been playing it for
Unfortunately you must buy a new one if it won't work even without the AR (action replay). If you're attempting to use it and it's not working, try using one code at a time. It might be the code itself that is corrupted.
How do I switch pokemon when I have more than six
In general? Go to a closest Pokemon Center and then boot up the pc you see in there. Click the first option and then it'll give you a choice to Move, Withdraw, and Pickup. In an actual battle? Click Pokemon on the bottom right corner then choose which one you want to switch with.
