20 Most Recent
LG WT1101CW 4.3 cu.ft. Ultra Large High Efficiency Top Load Washer Questions & Answers
How do I balance drum?
Check the spring,s are adjusted and none have been disconnected .put some clothes in the bowel to check the machine
I have got a front
Is the washing machine giving off a hot machine oil smell or making a grinding noise when the tub is turning? I've had to replace the drum bearings several times on LG front load washers. The first sign that the bearings are going are loud noises when the drum is spinning and eventually the hot machine oil smell. The bearings can be replaced but they usually last only 6 months to a year. The bearings are put on with a press at the factory and unless you are very accurate, you won't be able to get them on exactly straight and they will wear out quick.
10/27/2023 10:07:56 PM •
LG Washing...
Answered
on Oct 27, 2023
