20 Most Recent Everest Refrigeration EPR2 Questions & Answers
While chipping away at the
You will need a professional help with this..and yes ..it can be welded or the part changed and the unit filled with the freon again ..and will work ..I do not advice you to try to weld it at home ..even if you are handy or really good with a welder ..cause the temperature of the refrigerant is very low and the welding itself needs to be made in special conditions ..Also the refrigerant is on a very low temperature and handling it is very dangerous...
have a good day !
7/6/2011 2:58:11 AM • Everest... • Answered on Jul 06, 2011
2answers
Refrigerator repair
how burned compressor looks like inside. opened it up.
6/12/2016 3:07:50 AM • Everest... • Answered on Jun 12, 2016
0answers
0answers
Compresor fan
Be the first to answer 3/26/2014 3:27:51 AM • Everest... • Posted on Mar 26, 2014Be the first to answer
0answers
Cone error 4
Be the first to answer 1/22/2014 7:48:41 AM • Everest... • Posted on Jan 22, 2014Be the first to answer
0answers
An ESR2 is not cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/12/2011 2:30:34 AM • Everest... • Answered on Aug 12, 2011
Freezer temper 25 (selected -4) 2
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
7/12/2011 1:55:03 AM • Everest... • Answered on Jul 12, 2011
Suction pipe is freezing up
There is either too much refrigerant in system or its running and not cutting off on cold control/pressure switch,,....or the evaporator fan is not running...
1/16/2011 7:40:46 PM • Everest... • Answered on Jan 16, 2011
Compresor samsung SD162H L1U2 de arranque 9.9LRR 134A cual es su Hp y capacidad siendo de 60 HZ
Mi es de 1hp necesito saber c?mo van los cables de conexi?n el?ctrica al protector termico y el relay
4/24/2024 9:32:52 PM • Refrigerators • Answered 1 hour ago
4answers
Is it normal that the compressor is too hot too touch?
yes it is
4/24/2024 6:51:46 AM • Refrigerators • Answered 16 hours ago
2answers
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned. ..
4/24/2024 6:46:55 AM • Refrigerators • Answered 16 hours ago
DEFY DOUBLE DOOR FRIDGE MODEL DFF417. It is throwing out an error code OC2.
Question edited for clarity. Question moved from Cars and Trucks category. This is primarily a South African make and not one we know here in North America. This link should work better where you live and provide some insight. https://www.google.com/search?q=DEFY+DOUBLE+DOOR+FRIDGE+DFF417+error+OC2 ..
4/21/2024 5:36:56 PM • Refrigerators • Answered 3 days ago
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
4/16/2024 12:09:58 PM • Refrigerators • Answered on Apr 16, 2024
Everest Refrigeration EPR2 Logo
4 questions posted
Top Everest Refrigeration Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Everest Refrigeration Refrigerators
Most Popular Question
while chipping away
  • Refrigerators
