20 Most Recent
PHIL & TEDS SPORT BUGGY Jogger Questions & Answers
I am a grandmother left
If you have the Sport or Explorer model, then if you stand the folded chassis upright, so that the handle is touching/near the floor, and front wheel facing away from you, on the right hand side (the joint where the chassis folds) there is a light grey button which you press in, then pull the front wheel outward and lift the handle bar up, this should get the chassis open. Ensure that the chassis makes an auible 'click' when opened, that way you know it's up properly.
Hope this helps.
Need spring on a rainco
Rainco are a variant of the Fasco range. There will be a Fasco tool identical to your Rainco so take it to a Fasco stockist and yo'll sort it.
P&t front wheel sticks
Dear Jo B,Have you made sure that none of the fixing bolts or bearings that hold the wheels in place are stuck or seized? If they are not, then you might need to adjust any of the retaining springs that also fix the wheels to the rest of the stroller assembly (if these springs are indeed fitted). Any bearing grease, or even car axle/ CV joint grease will do fine. Some of these strollers also have a clip that you push down with your foot and it locks the wheels in certain positions. Check that this clip is not broken or misfitting, also check the brake bar too.Hope this helps and do let me know how you get on.Yours sincerelyOuszen
My tyres is flat and
Visit your local bike shop they'll pump up the tires and replace the tubes if required.
Replacement Parts Phil and Teds Stroller
hi .I'm in Queensland and have just placed an order for a front wheel n hood through my local stockist failing that perhaps get a cheepie off ebay and keep for spares!
My toddler is able to open belt buckes
I know how you feel, I had the same problem the only stroller that they could'nt open was perego ones,you can buy a baby buddy at albeebaby.com and attach it to the stroller, it buckles on the back so they can't open it,It worked for me..
