20 Most Recent
350HV ESP Security System 3Channel Car Alarm Questions & Answers
Viper Alarm app says Not Armed but locked
If the Viper Alarm app is showing that the alarm is "Not Armed" but the vehicle is locked, it is possible that the alarm system is not communicating properly with the app.
One solution is to try resetting the alarm system by disconnecting the car battery for a few minutes and then reconnecting it. This can sometimes help to reset the communication between the alarm system and the app.
If this does not work, it may be necessary to contact Viper customer support for further assistance. They may be able to provide troubleshooting tips or suggest a software update for the app or alarm system.
Ce0890. Do I need to reset after installing new battery?
The tablet should power on right after you install the new battery. However, you may need to hard reset it if it fails to start, or crashes immediately after booting. Note that hard resets will erase all your settings and dats. Hard reset should be the last resort. Before you do it, you may try starting the tablet in safe mode to determine whether the battery has sufficient capacity to power the tablet.
