20 Most Recent
Yamaha DVD-S520 DVD Player Questions & Answers
Not reading, seems to be laser pick-up problem
Sounds like the motors that control the angle and focus of the laser are going bad. Either find out what kind of replacement laser assembly would be needed and order it online, or get a new DVD player.
Why does my LG dvd keep freezing?
it could be dust inside of it if you run a dvd cleaner thru it you can get the disc at walmart or target check the dvds before you put them in to make sure no dust or finger prints
Yamaha DVD S520
yes sir, starting to malfunction and needs replacement now. unless you cant ry cleaning it manually maybe it will help a little but sooner or later it will again give you same trouble
DVD - S520 Player stuck on initialize
please check you TV color system. you are not using the right color frequency. if your TV has got an auto color region select then set it to auto. otherwise, select the TV color mode until you get the right color frequency
No Power
even if the power button is deffective, you can have it turned on using the remote contro. if still doesn't work then you have a problem with the power supply unit. you need to have it chekced by a service personnel
