20 Most Recent
Yamaha CDC-745 5-Disc CD Changer Questions & Answers
Sony cdp-ce525 drawer won't open
How old is the DVD player? I have a Yamaha 5-disk player and the rubber drive belt that wraps around the drawer motor and connected to the pulley for the drawer was stretched out and useless. Just bought a new one online and voila!
Disc will not play. door cycles open as soon as
Hi kirkwoodmc,
The first thing laser does is focus and if it never gets focus it will not spin up the disk. If the lens is dirty it will not spin. A cleaning disk with little brushes on the bottom, never spins up, hence never cleans. Please follow the following steps below to clean the laser.
1. Unplug the unit from the power outlet.
2. Remove screw from the cover.
3. Get isopropyl alcohol 80-90% pure from say Walgreen's. Original regular blue Windex works great also. With Q tip clean laser 1/4 inch diameter glass lens in circular motion and dry with other end.
4. This cleans dust off laser and works better than any cleaning disk.
If cleaning laser lens does not fix the problem, there is an internal problem with the player, laser needs replacement.
Hope it helps.
Thank you for using FixYa.
I need the drawer belt
hit the thingymajiggermabob inside of it with a hammer than it shall work if not get a new one problem solved
Need drawer belt for Yamaha cdc-805 CD changer
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
