20 Most Recent Yamaha P4500 Power Amplifier 2-Channel Questions & Answers
Circuit Diagram of Yamaha AS700
Sign up here, you should be able to download the service manual. http://www.hifiengine.com/manual_library/yamaha/a-s700.shtml
5/12/2014 12:57:25 AM • Yamaha P4500... • Answered on May 12, 2014
Fans Not Coming On, Yammy P4500 Power Amp
Hi...
It could be on a thermostat inside. I would check the connections to the fan.It might have it's own fuse.
If you have a meter ,you can check for DC volts to the fan and continuity on the thermostat (if it has one)
2 leads mounted on the heatsink ..usually black and round with slide-on terminals
4/5/2014 5:25:13 PM • Yamaha P4500... • Answered on Apr 05, 2014
Power supply output for Yamaha p4500 secondary
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
10/30/2013 4:33:43 AM • Yamaha P4500... • Answered on Oct 30, 2013
0answers
Schematic diagram of yamaha 4500 power amp
here is a link to guide you:Where do I Find a Service Manual?
7/28/2012 1:18:23 AM • Yamaha P4500... • Answered on Jul 28, 2012
Yamaha p4500 in protection mode
The manual says the heat sink is too hot or an unacceptable DC voltage was sensed going out.http://www.retrevo.com/support/Yamaha-P4500-Amps-manual/id/962bh144/t/2/Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech. Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
10/8/2011 11:34:28 PM • Yamaha P4500... • Answered on Oct 08, 2011
Hi We have an Allen &
'Splitting' leads is never the best way to distribute a signal. The best solution is to use the parallel inputs of the Yamahas to chain them together: mixer to amp1, amp1 to amp2, amp 2 to the Cloud. You should only need to use one input on the Cloud to drive all the channels, using the input switches at the rear.
Let me know if you need any clarification on this.
9/21/2011 1:34:47 PM • Yamaha P4500... • Answered on Sep 21, 2011
YAMAHA p4500 daigrem
This is a service manual of your device and it can be downloaded for free and I hope it is suitable for you (included schematic diagram). Go to this web site:
http://elektrotanya.com/yamaha_p4500.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading so please be patient.
Thanks.
gylacz
8/19/2011 11:01:29 AM • Yamaha P4500... • Answered on Aug 19, 2011
Protection signal is permanently one.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
7/3/2011 1:27:34 PM • Yamaha P4500... • Answered on Jul 03, 2011
The application of power amplifiers
5/25/2011 4:15:16 AM • Yamaha P4500... • Answered on May 25, 2011
0answers
Yamaha p4500 keeps blowing both
Suspect an overload in the power section, or more likely the main amp. A semi-conductor device is now acting like it was a piece of wire. Easy to spot with an ohm meter, it will just like you have touch the test probes together! My guess it will be one or more of the things on the big heatsink that's gone.
1/26/2011 8:32:11 PM • Yamaha P4500... • Answered on Jan 26, 2011
0answers
I have a Yamaha M-70 amp. The left channel cuts
There is a bad soldering joint somewhere. Take the top off and follow the speaker connections from where the left speaker connects. Keep an eye out. If you can get the bottom off, look at the PC board solder joints. If in doubt resolder them.
11/9/2010 3:47:00 PM • Yamaha P4500... • Answered on Nov 09, 2010
Yamaha P4500 Power Amplifier 2-Channel Logo
41 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
schematic diagram yamaha 4500 power amp
  • Audio Players & Recorders
