20 Most Recent
Hobart 500548 AirForce 500I Plasma Cutter Questions & Answers
I have a Hobart 251 mig welder and when I turn it on the wire comes out of the the gun and won't stop till I shut it off ?
If the wire feed on your Hobart 251 MIG welder won't stop when you turn it on, there could be a few possible causes. Here are a few things to check:
- Check the trigger on the MIG gun: Make sure that the trigger on the MIG gun is not stuck or damaged. If the trigger is stuck in the "on" position, it will cause the wire to continuously feed.
- Check the wire feed motor: The wire feed motor could be faulty or jammed, causing the wire to feed continuously. Try disconnecting the wire feed motor from the welder and see if the wire still feeds. If it does not, then the motor is likely the problem.
- Check the wire spool: Make sure that the wire spool is installed correctly and is not jammed or tangled. If the wire is not feeding smoothly from the spool, it could cause the wire to feed continuously.
- Check the wire feed control settings: Ensure that the wire feed control settings are set correctly. If the wire feed speed is set too high, it could cause the wire to feed continuously.
If none of these solutions resolve the issue, it may be best to contact a qualified technician or the manufacturer for further assistance.
I need a gun for the Hobart beta mig 170 welding machine
Lots of torches are fairly universal and you are likely to find it cheaper to replace only the parts needed if you can find them - manufacturers tend to prefer to sell the torch (or gun) complete with the hose, cables and sheath and they are expensive though considerable savings can be made dealing with factors or independent supplier/repairers.
Most professional mig welders over here use the euro torch and when a welder doesn't have one and the torch is ready for replacing it is a worthwhile modification, especially if the necessary parts can be sourced secondhand or salvaged.
The euro torch just plugs into the machine and once the machine has been modified there are plenty of usable secondhand ones about that can be had for a song.
If you aren't conversant with the euro torch, try a search...
Will a 5.7kva generator run a Hobart 175amp-230v-4.60kv welder
It’s close enough not to be able to answer that. The inrush current of a welder is huge anyway, so it could exceed the instantaneous capacity of the generator. However, it’s also possible with capacitance in the welder to smooth that out, that it will work fine. The only way to be sure is to test it. If you can’t do that before purchasing, it’s a risk you take. On balance it should work, but may not.
No generator on hobart g-213
When the generator is not used or
storage for a long time, the residual magnets contained in the iron core are lost before leaving the factory, and the excitation coil cannot establish the proper magnetic field. At this time, the engine is running normally but no electricity is generated. This phenomenon is stored in the new machine and stored in the humid. There are more units in the environment or long-term use.
