20 Most Recent
Yamaha RXV-350 Receiver Questions & Answers
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
What kind of speaker connectors I need to buy for
Special connectors are not required. It accepts twisted bare wire. I use 14-gauge lamp cord and prefer to bare the last 1/2", twist it into a nice tight bundle then solder it to hold the strands together and give the wire physical strength to withstand the various attachment hardware.
VOLTAGE SELECTOR
Not if it wasn't manufactured for an area of use that is running something other than 120 volts. If it wasn't imported then plug it in and go.
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Yamaha RX-V363 input settings
HI,you are not getting picture because the yam 363 dose not upscale or convert the picture from the composite input to hdmi.You will have to put a video cable from the composite out put on the amp to a scart convertor into the tv or put console picture into the tv and sound to the amp.
hope this helps.
CABLE GUY.
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
