20 Most Recent
Yamaha R-V1103 Receiver Questions & Answers
No remote control function
Set the large remote to "ALL" or "AMP" and it should work,the small remote is for zone 2.
hope this helps.
CABLE GUY.
Yamaha R-V1103 receiver cuts off immediately when turning unit on
Sorry but it sounds like you have a fault,guy came into shop were i work with same problem,i tried cables etc as you have but had to send it back to yamaha.It came back fixed with report saying board replaced,sorry can not remember which board.
hope this helps
CABLE GUY.
Sound gone
disconnect everything in the back of the unit. reconnect only the cd to the imputs. also,just to be sure, disconnect all speakers(label them). fire it up,play a CD, connect the speakers 1 at a time. If the 1st works you have hope ,if not, try each channel individualy.The one that reduces volume is the problem-maybe shorted cable, bad speaker,or , God forbid-Bad amp Channel. good luck
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
