20 Most Recent
Yamaha HTR-5560 Receiver Questions & Answers
Yamaha 5560 no sound from front left and right
hi,
just check by fault switched of the frond speakers. power on the receiver play some thing listen sound is coming from the other speaker except frond. press the speaker A button in frond of the receiver. listen is it become on. if not got to the menu of ur receiver surf for speaker configuration . find out the whether the frond speaker is off. if it off turn it on.
I've had the same
Sounds like the unit is set to shutdown if it detects a short in the amplifier. The problem can be within the supply but it is most likely in the amp section of the unit. Transistors will go out over time and need to be replaced. Find a local repair shop and have them estimate the repair for you. the cost on something like this can be in the 70.00 range depending on shop rates in your area and the extent of the problem.
Suddenly, I can only hear the sound faintly, even
Have you checked the MUTE function?
NEVER turn the volume up more than half-way for any sound problem. Otherwise, if you suddenly find the switch that's out of position you could blow your speakers.
What converter?
What channels, what source(s)?
