20 Most Recent Line 6 Spider Iii 75 Guitar Combo Amplifier Questions & Answers
I have a line 6 spider jam ...was playing guitar
Hello,It probably the output Ic named TDA7293 and maybe because of the fan malfunction, let me know a bit further to help you more.
11/4/2013 11:28:30 PM • Line 6 Spider... • Answered on Nov 04, 2013
Do you have the user manual
You can download the Line 6 Spider III 75 user manual here http://line6.com/legacy/spideriii75
4/8/2013 12:53:27 AM • Line 6 Spider... • Answered on Apr 08, 2013
The amp was working fine and than just stoped , it
The most likely problem in this instance is damage to the power supply, probably caused by a power surge. The second most likely cause is damage to the power cord. If you can take it to a shop that has similar amps on display, you can probably test it on one of there power cords. If the power supply is damaged, it will be a bit more challenging. At this point, if you know a bit about circuit boards and soldering, you might be able to fix it. If not, you will probably have to pay someone, or simply replace the amp.
3/14/2011 11:23:40 PM • Line 6 Spider... • Answered on Mar 14, 2011
Hi, it's a SpiderIII 75 and
This is most likely a thermal issue of some form.
Check the impedance of the speaker to be sure it's not partially blown and overloading (thus overheating) the amplifier and causing it to reduce power.
Another thing to look for is any electrolytic capacitors that might be bulging or leaking. They will need to be replaced if there are any.
2/27/2011 8:11:13 AM • Line 6 Spider... • Answered on Feb 27, 2011
Does it have a fuse and if it does where is it
Fuse is internal and unit needs to be repaired BEFORE replacing fuse as additional components may be damaged if fuse is replaced before repair is done.
1/15/2011 6:18:31 PM • Line 6 Spider... • Answered on Jan 15, 2011
My line 6 spider 3 75W amp will not show any
Probably the 3.3 volt power that supplies the DSP has failed or is being shorted out. If you are not electronicaally adept, best to take it to a shop for repair.
1/4/2011 7:26:06 AM • Line 6 Spider... • Answered on Jan 04, 2011
The hexagon nut came loose for the Guitar -CD/MP3
Those can be a pain to find. Some are Metric which worsens the problem. There are several types as well. I would first try Radio Shack where they have the drawers of jacks, etc. Those ore probably English thread...
The BEST source would be to search the DIGIKEY.com website for a jack that has the identical nut... the jacks are NOT expensive... under $2. Finding just the nut alone unless a repair shop for amps happens to have one laying around will be near impossible. It is worth trying that source however because USUALLY the jack inside is broken.
12/6/2010 3:23:33 AM • Line 6 Spider... • Answered on Dec 06, 2010
Line 6 Spider II 75 watt stopped sounding through
  • CHECK THE CONECTING WIRES ON BACK WIRE MIGHT BE LOOSE OR BROKEN.
10/25/2010 7:28:40 PM • Line 6 Spider... • Answered on Oct 25, 2010
How do you reset your
Hold down the settings/tone button as you turn on the power and keep holding it for 5 to 8 seconds. Here is a link you might like:http://line6.com/community/docs/DOC-4629
8/22/2010 8:44:37 PM • Line 6 Spider... • Answered on Aug 22, 2010
Line 6 Low Down 400 bass guitar head
Make sure the volume and master volume are turned up. Try the amp with a different cabinet and a known good speaker cable. If you get sound, it's your speakers or your speaker cable. If still no sound, you need your amp serviced.
10/20/2018 1:02:56 AM • Line 6 Music • Answered on Oct 20, 2018
0answers
3answers
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
7/7/2014 2:15:18 PM • Line 6 Music • Answered on Jul 07, 2014
0answers
0answers
Tda 75 72r
Be the first to answer 1/21/2014 2:25:08 PM • Line 6 Music • Posted on Jan 21, 2014Be the first to answer
Line 6 Spider Iii 75 Guitar Combo Amplifier Logo
16 questions posted
Top Line 6 Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Line 6 Music Expert? Answer questions, earn points and help others
View Most Popular
Line 6 Music
  • Line 6 Music
Most Popular Question
hexagon nut came loose guitar cd mp3
  • Music
