20 Most Recent Fender Pd250 Passport Deluxe 250watt Portable Sound System with Deluxe Speaker Array Pd250 Questions & Answers
2answers
Could a bad cable connection make a fuse blow in
A shorted speaker cable could cause this... however, what you do is to replace the fuse BUT wire a 150 Watt lamp in series with the power input... This acts as a resetable fuse for testing. If the lamp stays lit, you still have a failure.
9/17/2012 11:36:51 PM • Fender Pd250... • Answered on Sep 17, 2012
2answers
We have a Fender P-250 PA system. We get the
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
4/24/2012 8:55:46 AM • Fender Pd250... • Answered on Apr 24, 2012
My passport 250 goes into protect mode on
These seem to be tempermental. I would look for radio frequency interference from nearby transmitter leaking into your guitar cable or mic cable that puts this on the ragged edge of feedback. DO NOT boost highs with the EQ... You can get supersonic feedback that you can't hear, but puts the amp into limiting. Any audio input can start the feedback. These amps are VERY hard to work on due to the packaging. A lot of people have smoked their units and then require repairing.
5/24/2011 2:52:50 PM • Fender Pd250... • Answered on May 24, 2011
Fender Squier Stratocaster serial number CY01084527. What year was it made and the value please?
Your squier guitar is from 2001 Says the last link. For value, check eBay sold listings.
Serial Number Lookup
Fender Guitars https://serialnumberlookup.fender.com Fender is proud to now offer self-service serial number search function. Feel free to bookmark the link for future reference, and please be aware that not every ...
Serial Number Tracking
Squier Wiki http://www.squierwiki.com > Serial-Number-Tracking The serial number is printed on a sticker located on the back of the neck, close to where the neck attaches to the body. Because the number was placed on a ...
Squier Serial Number Lookup
Authority Guitar https://authorityguitar.com > squier-serial-number-loo... Mar 8, 2023 - It's simple enough with our squier serial number Checker. Type your serial numbers into the decoder below and you'll get all the information ...
Squier Serial Check
Squier Serial Check http://guitarcheck.info Squier Guitar Check (1982 - 2011). Serial number. Serial Number should be 6-12 characters. Serial Number is required. Country of origin. Select Country, CHINA ... ..
12/30/2023 6:14:49 AM • Fender Music • Answered on Dec 30, 2023
2answers
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
12/15/2023 7:48:03 PM • Fender Music • Answered on Dec 15, 2023
Fender G-DEC Amp. How do I reset my Fender g deck amp to factory settings please?
Question edited for clarity and correct name of Amp. https://www.google.com/search?q=Fender+G-DEC+reset
Advanced Owner's Manual - fmicassets.com
fmicassets.com https://www.fmicassets.com > Damroot > Original PDF Preset Restore will NOT restore any media (band tracks) if they have been deleted from the G-DEC 3 hard drive (HD), which can only be done using the Fender FUSE .. ..
5/7/2023 2:28:42 AM • Fender Music • Answered on May 07, 2023
2answers
How can i control 2 different fender hot rod deluxe 3's drive channels with just 1 footswitch? Thank you in advance
You could buy a Lehle switch, or simply use one on each separately. If you are using a multieffect unit you could make a Y cable to take the output to both amps but that will not allow you to select the drive channel - you still need the Fender footswitch for that, one for each amp. Lehle is a German company and they make a lot of different footswitch combinations but you will pay for the convenience. I recommend the Fender single button footswitch for this use - Type: Footswitch
  • Number of Footswitch Buttons: 1
  • Manufacturer Part Number: 0994052000
  • It's about $35.00 each, compared to the Lehle which starts at $200. Just put the two side by side and make a metal bar to attach to the two switches - then you have a single bar to activate both drive channels at the same time. I recommend using aluminum bar stock with holes drilled into it for the switches, or find a C channel aluminum bar that will put the footswitch buttons in the channel. You can also make it one inch overhang past both switch bodies and then use bolts to keep the bar in place. If I was doing this I would mount the footswitches on a board and secure the bar to be on top of the footswitches, using coil springs to maintain the bar's alignment vertically at the end bolts.
  • 11/22/2022 1:29:51 PM • Fender Music • Answered on Nov 22, 2022
    Guitar amp input not working
    Get inside it and check the connections to the plug especially any shielding / braiding. Resolder the connections.
    4/17/2022 3:41:52 PM • Fender Music • Answered on Apr 17, 2022
    Fender bxr100 bass amp: while playing volume decreased to zero over a few seconds then smoke. Ideas? Rectifier?
    I would suspect that the issue is filter capacitors that have gone bad.. The amp is of the mid 90's era. You should be able to spot the failed parts if you have the proper knowledge about what to look for. Here is the schematic fender_bxr-100_sch.pdf_1.png (1529×990) (elektrotanya.com)
    7/20/2021 2:09:26 AM • Fender Music • Answered on Jul 20, 2021
    Fender banjo 130300028 Year type & value
    https://support.fender.com/hc/en-us/articles/212774866-How-can-I-find-out-when-my-old-Fender-banjo-was-manufactured- https://www.banjohangout.org/group/fenderbanjoowners/blog/6069
    Product Dating - Fender
    support.fender.com > en-us > 202726846-Product-Dating
    Product Dating. Find out exactly when your instrument or ... How can I find out when my old Fender® banjo was manufactured? How can I find out how old my ...
    Fender Banjo Serial Numbers Kd - engswift's diary
    engswift.hatenablog.com > entry > 2019/12/24
    Dec 24, 2019 - Look on the headstock of the guitar to find the serial number for a Fender Stratocaster. It may be located on the front or the back. The serial ...
    Fender Instruments Serial Number Dating Guide ' The Music ...
    www.themusiczoo.com > blogs > news > fender-instru...
    May 18, 2010 - For years, serial numbers have been used in various locations on Fender instruments, such as the top of the neck plate, the front or back of the ...
    Fender Banjo Serial Numbers? - narkive
    alt.banjo.narkive.com > awlepEsk > fender-banjo-serial...
    heads with a "soundhole" in it!) Anybody know if and where there might be a list of Fender banjo serial numbers that can be used to date this critter? Fender says
    12/19/2020 8:29:18 PM • Fender Music • Answered on Dec 19, 2020
    I have the fender passport 500 and use it as a karaoke system. Its been working fine but all the sudden now we have to turn the volume almost full blast to make the music loud to sing with. Before we always had it half way. Any help would be appreciated.
    This could be the speakers that have become damaged or the final audio transistors. It would require you to have a way to test them to be sure which it is. The speakers can be tested with an OHM meter to see if the voice coil is bad. To test the amplifier you would need more specialized equipment like a scope, audio watt meter or component tester, To use the component tester or to perform service on the unit you will need to be able to solder.
    11/7/2020 3:04:29 PM • Fender Music • Answered on Nov 07, 2020
    How does a fender ax-12 chromatic tuner work
    I'm an engineer, not a musician. The device is a frequency meter set up to display the musical note input to it. If you pluck a C flat and it shows an A you need to tune your instrument till it shows a C flat. You will have to refer to the manual for operation and modes.
    12/4/2019 8:43:15 PM • Fender Music • Answered on Dec 04, 2019
    I pluged my pc into my input on my amp and the amp went out, could it be a fuse? its a fender princeton chorous with red knobs, early nineties
    yes check the fuse . there is generally a fuse for power switch and that sounds like what your having trouble with. hope that helps you out.
    9/27/2019 10:25:16 AM • Fender Music • Answered on Sep 27, 2019
    2answers
    Can you please advise? My Fender Blues Deluxe re-issue 180W has a humming buzzing sound which is not clean. Yesterday I used it, was fine and turned it off. Today I have the buzzing problem.
    Does it still have a hum/buzz when NOTHING is plugged into the INPUT? If so, you MAY have a tub going bad. If the noise is only there when you have your guitar/effects, etc. plugged in, then the problem is the guitar grounding or effects faulty... FIRST: When the amp is "cool", UNPLUG THE AMP POWER CORD FROM THE WALL! ! ! ! Then CAREFULLY remove and reseat the tubes one at a time. Be sure to insert back into the socket correctly. You MAY just have a bit of corrosion on the tube "pins".... SECOND:Don't plug anything into the amp, turn on and warm up. GENTLY tap one tube at a time with a WOODEN pencil. DO NOT USE anything metallic (like a screwdriver....) and be VERY gentle. If the noise increases or decreases, you probably have a tube going bad... That's all I have. If this doesn't cure the issue, best take it to a repair shop . . . .
    9/27/2019 10:19:13 AM • Fender Music • Answered on Sep 27, 2019
    2answers
    Fender stage 100 loud hum/buzz. Even with the guitar plugged in. And also when it’s not
    While it is possible (probable) it is caused by the AC mains modulating the output due to a power supply fault, it could be caused by inadvertently creating a hum loop due to poor grounding - check out the link below... https://www.google.com/search?q=hum+loop+audio&rlz=1C1CAFB_enGB673GB676&oq=hum+loop&aqs=chrome.4.69i57j0l5.8500j0j8&sourceid=chrome&ie=UTF-8
    9/27/2019 10:17:07 AM • Fender Music • Answered on Sep 27, 2019
    Fender Pd250 Passport Deluxe 250watt Portable Sound System with Deluxe Speaker Array  Pd250 Logo
    6 questions posted
    Top Fender Music Experts
    Sean Wright
    Sean Wright
    Virgil Watts
    Are you a Fender Music Expert? Answer questions, earn points and help others
    View Most Popular
    Fender Music
    • Fender Music
    Most Popular Question
    could bad cable connection make fuse
    • Music
