20 Most Recent Waterco Baker Hydro 55K Btu Titanium Automatic Pool Heat Pump Questions & Answers
My heatpump, a Waterco Aqua Heat XL Titane 101, now display error code "ot". What does it means and how can it be fixed?
I think that replacing the temp sensor will solve this problem.
6/8/2021 3:31:29 PM • Waterco Pool &... • Answered on Jun 08, 2021
Waterco pool heat pump displays error code "ot"
Pull thermistor out and clean it with rubbing alcohol and reseat it. Reseat all wire, harnesses, plugs, relays, etc. that are attached to it.
11/25/2020 12:10:13 PM • Waterco Pool &... • Answered on Nov 25, 2020
Error code on my waterco titanium pool water heater says nFL.
NFL code: No water flow, not sufficient water flow through the pool heat pump or the water pressure switch needs to be adjusted or is defective.
5/8/2020 11:08:44 PM • Waterco Pool &... • Answered on May 08, 2020
Hi have a waterco supastream 150 pool pump. When turned on it makes a humming noise doesnt pump, but if you switch it on and off a few times it fires up. What could be the problem? Regards Nicky
Will either be the start capacitor (in the box on top of the motor) or something binding the impeller or potentially both. There is a fan cowling on the rear end of the pump try this; - Turn the power off - Remove the cowling - See if the fan allows you to spin freely/easily the pump BE SURE nothing could become entangled in the fan - Turn pump back on - If it starts, probably something on the impeller side - If it doesn't but will start with a little turn of the fan probably the capacitor. Get a new one from Jaycar or RS components Remember to put the cowling back on safely.
3/22/2019 3:03:16 AM • Waterco Pool &... • Answered on Mar 22, 2019
0answers
Motor cuts out after running for 15 mins. Then comes on again after a few mins. Why?
Sounds like it is overheating. Because of electrocution hazard around pools I suggest replace any of it if you even suspect a problem.
10/13/2017 11:15:37 AM • Waterco Pool &... • Answered on Oct 13, 2017
How much sand goes in a waterco 8600 sand filter
Leave 10"-12" empty space above sand (freeboard).
2/12/2017 4:03:00 PM • Waterco Pool &... • Answered on Feb 12, 2017
Waterco Baker Hydro 55K Btu Titanium Automatic Pool Heat Pump Logo
0 questions posted
Top Waterco Pool & Spa Experts
Jay Finke
Jay Finke
 Mikey
Mikey
Are you a Waterco Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Waterco Pool & Spa
  • Waterco Pool & Spa
Most Popular Question
waterco t800 sand filter
  • Pool & Spa
