20 Most Recent Watts Etq Portable Generator6950 Questions & Answers
3answers
Is it safe and could I make a 120 outlet from a 220v 2 wire hot, shield grounded range outlet?
No, you can't do any of that. A 60 amp breaker would allow the microwave to burn first before the breaker tripped. This is an easy job for an electrician to do, get it done to code specs. It is worth having it done right for a couple of hundred bucks that burning the hose down or turning all the earth points into a voltage sink.
4/11/2022 11:56:49 AM • Watts Electrical... • Answered on Apr 11, 2022
2answers
How do you replace the pull cord on a Powermate 5000 rated Watts on a generator
Visit the website to get more support: www.dieselgeneratortech.com.
10/9/2019 5:14:21 AM • Watts Electrical... • Answered on Oct 09, 2019
2answers
Can you parallel eastern steel generator to another generator to increase watts
It is necessary to pay attention to the problem of uniform distribution of load power among generators in parallel. The parallel operation of diesel generator sets should first meet the requirements of uniform power distribution. The uniform distribution of power includes active power and reactive power.
11/27/2018 9:30:52 AM • Watts Electrical... • Answered on Nov 27, 2018
What type spark plug need for pro force powermate generator 3125 max watts
what make of engine is in it plug specs are on a decal somewhere around the plug or in the operators manual search -- operators manual for powermate generators -- as the engines will all run the same plug for that make of engine
10/8/2018 12:04:28 AM • Watts Electrical... • Answered on Oct 08, 2018
I am about to buy a petter paz1 gen set. But I found that under load it belt black smoke the generator is a 3.5 kva the jug I put on draws 2.4 watts it seems to strugel with just a jug
understand that the advertised capacity is not the real capacity of a gen set The 3.5 kv is max for a short time and that is in reality full load of around 2.8 kv full time rated load Black smoke is over fueling and as you cannot mention if petrol or diesel then the problems can be very different for petrol it is choke ,blocked air filter if diesel it is bad injector, pump out of calibration or incorrect injection timing
7/18/2018 9:48:32 AM • Watts Electrical... • Answered on Jul 18, 2018
How do you convert power requirements from a 220 volt system to a 12volt system?
Eighty watts is constant regardless of what voltage you pick. So get a eighty watt twelve volt motor. Satisfy the wireing requirements for whichever motor satisfies your heart.
HP = torque x rpm / 5252. = 746 watts
You do your own juggling with your known values. All you give is 80 W.
5/19/2018 10:34:55 AM • Watts Electrical... • Answered on May 19, 2018
What kind of generator oil does it take for a 1200 watts pulsar model no.PG1202S I use a 2-cycle engine oil but it makes oily in the muffler
Use the oil designed to be mixed with your fuel. Available at all outfits that sell generators, etc. Walmart and home depot have it.
9/9/2017 3:50:37 PM • Watts Electrical... • Answered on Sep 09, 2017
Need a wiring diagram for a 1982 generator model number 4BPH SE/F4 4000 WATTS
need more info---a name brand of generator with engine type and double check the model number---could not research any info as something missing somehow----I'm not trying to get smart but nothing seems to cross??
6/12/2017 12:40:13 AM • Watts Electrical... • Answered on Jun 12, 2017
400 watts on 120 volts is how many amps
3.3 amps
6/2/2017 6:44:51 PM • Watts Electrical... • Answered on Jun 02, 2017
Armature for generator power stroke 6000 Watts where can i get one?
from the sevice agent that does the services on that brand of machine
1/24/2017 7:18:25 AM • Watts Electrical... • Answered on Jan 24, 2017
My eagle creek generator 1200 watts starts and runs but has no ac output. What's wrong with it?
It needs re-energising believe it or not! I had the same problem. Google "Reenergise generator" Or check this Youtube: https://youtu.be/sYBZrjeaDVc
11/8/2016 10:59:40 AM • Watts Electrical... • Answered on Nov 08, 2016
I need a repair manual for my champion generator
You can't download the manual free, you must purchase it thru the manufacturers parts division.
10/19/2016 8:28:46 PM • Watts Electrical... • Answered on Oct 19, 2016
Where is the coil located on my craftsman 5600 Watts generator
Follow the spark plug wire back into the generator. It ends at the coil.
7/29/2016 5:20:17 PM • Watts Electrical... • Answered on Jul 29, 2016
How is watts we use in pakistan there watts is 220
Any Generator with standard Euro plugs should work in Pakistan. 230 VAC
4/27/2016 10:32:44 PM • Watts Electrical... • Answered on Apr 27, 2016
Where can I get a wiring diagram for a 3250- watt generator?
go google and type in-- schematics wiring diagram for watts 3250 generator set-- and if one is available it will be pdf version download
1/4/2016 10:17:06 PM • Watts Electrical... • Answered on Jan 04, 2016
We have a Powermate portable generator about 15-20 years old. We no longer have the manual to it & would like to get one. Please advise
Google the PM542000 as the manufacture no longer provides the op manual just a parts list.
5/16/2015 9:21:38 PM • Watts Electrical... • Answered on May 16, 2015
Watts Etq Portable Generator6950 Logo
0 questions posted
Top Watts Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Watts Electrical Supplies
Most Popular Question
safe could make 120 outlet from 220v 2
  • Electrical Supplies
