Have a Husky 18" bar, 350/351 49cc model. 2
The throttle lock or dead man can be removed fairley easily, carefully splay the opening where the latch fits, at the same time pry the back end of the latch up,there is two small legs on the back that hold it in, once out it will pop up at the back, now pull it back toward the back of the saw and it will come away, it will expose the return spring, to remove the throttle trigger itself with the spring, tap out the steel pivot pin at the side of the trigger, through the orange tank, once removed pull the trigger back and out through the bottom of the rear handle, to remove the throttle push rod to the carb, remove the top cover, remove the air filter, gentlty pull back the leg of the return spring on the carb spindle ( this stops the rod jumping out of the spindle, ) do not deform this spring, hold the throttle full open on the carb with your finger, grab the rod with your other fingers and pull it out and back to remove it,check that the plastic end that slides into the tank is not badly worn, this is why they jam, whilst you are in there, look at the back of the red stop switch, the earth cut out wire which has probably come out, fits into the cut a way on the side of the switch, the metal terminal slides into the side of the red switch
the hole in the plastic is the same profile as the metal terminal, if it is too loose, splay the sides of the terminal out slightly to make a tighter fit.
9/8/2011 8:18:36 AM •
Husqvarna...
Answered
on Sep 08, 2011
