20 Most Recent McCulloch 14" Electric Chain Saw Mcc1514 Questions & Answers
McCullough Eager Beaver model#40010205 392 chain saw manual/parts
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rx44h4hsqebyqg3voy0wii3n-2-0_5.png
3/10/2018 5:36:26 AM • McCulloch 14"... • Answered on Mar 10, 2018
File size for chain McCulloch 14
Yes, no, maybe... I recommend contacting your local authorized service center for assistance. You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rwwceix4simen0bu2pand4lt-2-0.png
3/1/2018 5:57:02 PM • McCulloch 14"... • Answered on Mar 01, 2018
What size file to sharpen the chain and the correct angles for mcculloch mcc1514?
If you've not performed this operation before, I recommend contacting your local authorized service center for assistance. You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rwwceix4simen0bu2pand4lt-2-0.png
2/20/2018 3:54:37 AM • McCulloch 14"... • Answered on Feb 20, 2018
Need clutch for mcc1514
Hello, You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... User manuals McCulloch Service I trust this information proves beneficial. helpful-rwwceix4simen0bu2pand4lt-4-0.png
2/19/2018 6:19:56 AM • McCulloch 14"... • Answered on Feb 19, 2018
What size file do I use to sharpen my blade?
A good rasp that is easy to use and takes off sufficient material. Otherwise, I recommend contacting your local authorized service center for assistance. You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... User manuals McCulloch Service I trust this information proves beneficial. helpful-rwwceix4simen0bu2pand4lt-4-0.png
2/19/2018 6:12:53 AM • McCulloch 14"... • Answered on Feb 19, 2018
MCC1514 oil
Most any chainsaw , chain oil . Just so it is not dirty and will not clog the oiler.
7/3/2016 1:07:42 PM • McCulloch 14"... • Answered on Jul 03, 2016
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
7/29/2015 1:22:27 AM • McCulloch 14"... • Answered on Jul 29, 2015
My saw runs great for
There are several things that can cause this problem First if you run it until it quits will it start working again after it cools down. If this is the case the it is shutting off thermal switch on motor. This could be from saw needing cleaned or lubed, make sure chain is not to tight, don't force saw to hard,let it cut at its own pace. Make sure chain is sharp. Anything that causes excessive friction will increase motor temperature. It is possible that thermal switch is about worn out. Hope this helps. Thanks
8/4/2014 7:25:34 PM • McCulloch 14"... • Answered on Aug 04, 2014
Chain moves when trying to start
Either the sprocket bearing is dry or has broken up, or the clutch spring has broken, either way you need to remove the side cover, bar and chain, if the drum does not turn freely it is the bearing in the centre giving problems, you should also be able to see the clutch and springs from here, check there condition.
8/17/2013 8:35:14 PM • McCulloch 14"... • Answered on Aug 17, 2013
0answers
Chain came off
Loosen the bar and if there is an adjustment screw, turn it so the bar moves in the direction of the motor. Slip the chain back into its groove and turn the adjustment screw in the other direction until the chain is at the proper tension. Tighten the bar.
6/26/2011 4:00:41 PM • McCulloch 14"... • Answered on Jun 26, 2011
How to fit new oil
dfdfdsf
6/10/2011 1:32:04 PM • McCulloch 14"... • Answered on Jun 10, 2011
Sharpen chain with an electric sharpener
Having cut a lot of wood when I was younger I know from experience just how important a sharp chain is.You need a guide so all the teeth cut at the same angle.If I were doing it now I would use an outfit like this.You will find that when your out cutting that it won't take much to dull a chain and that cuts in to the sprocket that turns the chain.A sharpe chain will throw big chips whill a dull chain will through out small chips because it's scratching the wood instead of cutting it off.We just used files without guides.I never did get the hang of that But my partner did.This is what I would use today.By the way never use a chain saw alone ,that way you have some one to help you if something goes wrong. I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.I am not endorsing this site just the type of tool.
right-tool_2143_15026
right-tool_2147_24719010trans_1x1.gifright-tool_2147_24738108
The Precision Granberg Chain Saw Grinder combines the features of the Grind-N-Joint with the accuracy of the File-N-Joint. Easily clamps onto the saw bar for fast, precise, and stable chain saw sharpening.
This grinder requires threaded stones. SEE BELOW.
GI-G1012Ctrans_1x1.gifRegular: $70.00trans_1x1.gifSpecial: $59.94trans_1x1.gif
Calculate Shipping Rates Zip Code: Country:
trans_1x1.gif Granberg G417-3 5/32" Grinding Stones (Threaded # 31399)trans_1x1.gif3-Pack
trans_1x1.gif trans_1x1.gif Granberg G418-3 3/16" Grinding Stones (Threaded # 31401)trans_1x1.gif3-Pack
trans_1x1.gif trans_1x1.gif Granberg G419-3 7/32" Grinding Stones (Threaded # 31400)trans_1x1.gif3-Pack
GI-G419-3trans_1x1.gif$9.27
5/27/2011 6:26:25 AM • McCulloch 14"... • Answered on May 27, 2011
Chain has come off how
The chain drive links may well be damaged now, it may need a new chain, however,if it has a chainbrake make sure this is off by pulling the hand guard fully back to the top handle,wind the chain adjuster fully back, remove the the side cover nut and remove the side cover, push the guide bar fully back, loop the chain over the drive sprocket, and lay it into the guide bar rails ( the cutters on the top bar rail should face away from the saw ), refit the side cover, if the adjuster pawl is in the cover make sure it aligns with the hole in the guide bar, fit the bar nut finger tight, adjust the chain so as it fit snuggly all round the bar, with a gloved hand pull the chain around the bar to ensure it it is sitting in the sprocket and rails properly, re adjust the chain if it has come lose, now fully re tighten the bar nut. If you fit a new chain there will be an amount of initial stretch, so re tention after a few cuts.
4/21/2011 7:49:53 PM • McCulloch 14"... • Answered on Apr 21, 2011
Can you help me. My "trigger"
I was able to make my own by going to the local hardware store and buying 2 nylon parts and doing some careful milling/filling. The following dimensions were checked against an original EM14e trigger. These instructions may or may not work with other McCullough Chainsaws, but they worked for me!
1.) buy a nylon thumscrew with a 3.20mm (.125 in) outer diameter and 13.2mm (.5 in) THREADED length (overall length varies depending on type of flat head used for thumbscrew and overall total length will likely exceed 18mm or .75 in)
2.) a nylon spacer .25in length and .125in inner diameter that I cut in half and used a shop grinder to loosely fit onto a mounting nail. I used the shop grinder to gently mill down to 8.7mm outer diameter by slowly pressing the spacer/nail combo against the grinder wheel.
I then tested in the EM14E handle to check for fit and after several trips to the grinder for the spacer, it works great.
3.) After checking for fit I glued the thumscrew and spacer together and am now able to use the trigger. Please note if you have a working loose fit for the trigger, do what I have and simply use masking tape to keep the trigger with the chainsaw so it does not get lost.
4/3/2011 7:29:57 AM • McCulloch 14"... • Answered on Apr 03, 2011
Where can I buy a fuel priming bulb, vinyl/soft
You can go to the carburetor manufacturer's website and look for parts. You will need the numbers of the carburetor in order to get the correct one. Alternately, you can go to a mower shop near you and they should be able to get you one or point you to a place that will have the part you are looking for.
3/31/2011 4:59:14 AM • McCulloch 14"... • Answered on Mar 31, 2011
Removing a link to shorten...stretched
It is never a good idea to shorten a chain, if it has stretced that bad you need to replace it, or it will snap, the chain does not have a joiner, you would need to break the chain, and re rivet a new pre set tie strap.
3/26/2011 10:13:03 PM • McCulloch 14"... • Answered on Mar 26, 2011
I have a Mcculloch electric
This is a full strip, and split side covers to get to the pump, this may well be a job for the local repair agent, having been apart it should then be PAT tested to ensure the double insulation it still good.
3/21/2011 8:57:18 AM • McCulloch 14"... • Answered on Mar 21, 2011
McCulloch 14" Electric Chain Saw Mcc1514 Logo
36 questions posted
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
View Most Popular
McCulloch Garden
  • McCulloch Garden
Most Popular Question
chain came off
  • Garden
