20 Most Recent Husqvarna 455 Rancher 555cc 35 hp 20" Chain Saw Questions & Answers
2answers
I can not find a bar to fit the rancher 55. This
The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
3/6/2015 3:57:00 PM • Husqvarna 455... • Answered on Mar 06, 2015
Changing the chain
remove the 2 nuts holding the sawdust strut/sidecover and remove side cover. remove chain and bar. clean the chain slot and oil holes on bar. install new chain over bar and place remainder of chain over chain sprocket.back off chain tightener until chain and bar fit. reinstall side cover.
11/25/2013 2:57:26 AM • Husqvarna 455... • Answered on Nov 25, 2013
455 rancher engine bogging down and starting to
Make sure you are using the correct fuel mix. Check fuel tank vent, prone to blocking an can effect the performanceClean air filter, check Spark plug.
8/15/2012 1:06:32 PM • Husqvarna 455... • Answered on Aug 15, 2012
The oil pump seems to
You have to remove the bar and chain, then remove the clutch by getting a hard plastic plug at your nearest shop. You then screw in the plug into the spark plug hole. You turn the clutch clockwise as opposed to counterclockwise. The oiler is underneath the clutch. They have a plastic gear that tends to wear out with time. You have to replace that gear . Buy the gear and the seal . Also clean the oiler real good so that it runs fairly free. They get clogged to the point of not turning sometimes.
12/3/2011 7:55:01 AM • Husqvarna 455... • Answered on Dec 03, 2011
Refilled the fuel on my Huskvarna chainsaw and now
Just check that it is mechanically sound, remove the muffler and check the condition of the piston skirt through thre open exhaust port, any signs of scuffing or damage and the cylinder will have to come off the assess the damage,
10/25/2011 3:56:25 PM • Husqvarna 455... • Answered on Oct 25, 2011
I have a rancher 455 and it's not suppling
The 455 has a 3 position adjustable oil pump, the adjuster screw is up under the crankcase, sprocket side, you need a flat blade screw driver.
10/11/2011 1:03:14 PM • Husqvarna 455... • Answered on Oct 11, 2011
55 rancher-put new after market piston,ring and
I had a very similar problem with a stihl 029 farm boss.I did everything you did except I took it to a shop to do the piston and ring replacement. When I got it back the first time it would run for about two mins. then die.I fought it for a couple of weeks then took it back and expressed my displeasure. Then checked it all over and replaced piston and ring again and it runs great. They told me they could not get the right compression with the first one and thought the groove for the ring was cut to deep.I hope this is of some help to you. Thank you.
3/21/2011 6:09:41 PM • Husqvarna 455... • Answered on Mar 21, 2011
Will start but will not stay running
The 455 was very prone to blocking the fuel tank vent, as a test, when the saw starts to die release the fuel cap, if the saw picks back up and runs normally it is a breather issue, the breather is pressed into the crankcase under the starter cover.
2/27/2011 12:27:06 AM • Husqvarna 455... • Answered on Feb 27, 2011
2answers
How do I find out what year my Husqvarna yth18542 42 in riding lawn mower was made in
yth18542 is the model number of the lawn tractor, the identification plate should also show a serial number, which can be used to identify the date of manufacture as well as to differentiate between differences in this model, depending on date of manufacture. https://www.husqvarna.com/us/products/riding-lawn-mowers/yth18542/960430172/
4/16/2024 6:17:40 AM • Husqvarna Garden • Answered on Apr 16, 2024
2answers
Governor on briggs 445677
Looks like your governor crank broke. Go to www.parttree.com
4/12/2024 1:16:56 AM • Husqvarna Garden • Answered on Apr 12, 2024
What kind of blade can i put on my Husqvarna 322L weedeater to cut little trees up to size 1/2 to 1?
copy and paste into search engine Husqvarna Blade Conversion 537048502 537 04 85-02 322L 323L 324LX 325LX 326L
3/21/2024 4:41:48 PM • Husqvarna Garden • Answered on Mar 21, 2024
2answers
I have a Husqvarna HU700F. I need a new grass bag. I can only find one for an HU700. Would that fit?
Here is the bag, use your existing frame https://saffordequipment.com/product/husqvarna-black-grass-bag-oem-580947302/ Husqvarna Black Grass Bag OEM #580947302 **Bag Only, Does not come with Frame** Compatibility This part is compatible with the following machines: Husqvarna HU700F (2012-11)(96145000900) Walk Behind Mower Also available at Walmart and Sears https://www.google.com/search?q=husqvarna+hu700f+grass+bag
OEM Husqvarna 580947307 Fabric Grass Bag ONLY For ...
Walmart https://www.walmart.com > OEM-Husqvarna-580947... Husqvarna. OEM Husqvarna 580947307 Fabric Grass Bag ONLY For HU550F HU550FH HU700F HU800H. USD Now $55.00. You save $14.58. You save$14.58. was $69.58$69.58. US$55.00 ..
1/28/2024 8:02:53 PM • Husqvarna Garden • Answered on Jan 28, 2024
Husqvarna YTA24V48 Lawn Tractor. Need drive belt diagram for it please?
Question edited for clarity. Shown on Page 20 of the manual. https://www.manualowl.com/m/Husqvarna/YTA24V48/Manual/493664?page=20 ..
11/29/2023 9:34:18 PM • Husqvarna Garden • Answered on Nov 29, 2023
Husqvarna zero turn 560 lawn mower how do I raise the seat
See attached. .. manual available at
https://www.husqvarna.com/us/support/z560x/
11/25/2023 1:15:01 PM • Husqvarna Garden • Answered on Nov 25, 2023
How do I pour gas into my carborator when I run out of gas
why, just fill tank
10/28/2023 8:18:43 PM • Husqvarna Garden • Answered on Oct 28, 2023
3answers
Husqvarna zero turn mower. Starts ok, but when I bring in the right handle the engine dies. The left is ok, I can move it in and go forward slightly with it, but when I engage the right handle the engine shuts off.
Your seat safety switch is not working. If the seat switch isn't activated, ie. a person sitting on the seat, the safety system will stop the engine when the levers are engaged. There is probably only one lever safety switch, on the right lever, which is why the left one doesn't kill the engine. Check the seat switch continuity and the wiring for loose connections.
10/7/2023 2:37:40 AM • Husqvarna Garden • Answered on Oct 07, 2023
2answers
Husqvarna RZ46i 46-in 23-HP V-twin Gas Zero-turn Riding Lawn Mower. It starts then engine revs up, no control.
Question edited for a lot more clarity! The throttle return spring has broken or come unattached. more here https://www.google.com/search?q=Husqvarna+RZ46i+runs+full+throttle ..
10/4/2023 12:05:24 PM • Husqvarna Garden • Answered on Oct 04, 2023
Slow forward drive on hydrostatic mower husqvarva 316 tsx awd
Likely there is air trapped in the system. Try raising drive wheels (safely) off the ground and operating forwards backwards. With minimal load on the hydo pump and motor, the air should purge.
9/22/2023 1:39:14 PM • Husqvarna Garden • Answered on Sep 22, 2023
2answers
Husqvarna 128CD weed eater. The flywheel is tight, piston is at bottom when flywheel magnet is in contact with coil. How can I change it to correct position.
The flywheel key has likely sheared. Contemporary utility 2-cycle flywheel keys are integrated into the flywheel. A new flywheel will be likely be required.
9/7/2023 10:16:53 AM • Husqvarna Garden • Answered on Sep 07, 2023
Husqvarna 455 Rancher 555cc 35 hp 20" Chain Saw Logo
11 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
will start but will not stay running
  • Garden
