20 Most Recent
Ge Medical Systems GE Dash 2500 Vital Signs Monitor w 104 in Display w Masimo SpO2 ECG NIBP Printer () Questions & Answers
Can't change date or time on MACvu EKG machine
go to the system menu and put in the password which is usually OVEREAD or SYSTEM. After that you can go to the misc. setup and then date and time. If the password does not work you will have to restart it and I can send directions on that if necessary.
[email protected].
www.overstockme.com.
Jeff Watson
Our ekg machine starts but sometimes will not
Without knowing what model I cant narrow it down too much. Some of the reason are that you are using the wrong paper. You should open the paper compartment and leave some hanging out and see if the paper advances and where it stops when it is done.
Also, you may not have put in all the patient demographic info that is needed but usually an error message will come up to let you know. It might be set to store only instead of print and store. If you tell me which model and try the things I listed I can be more helpful. Also, if we cant get this resolved over email you could send it to my Biomed and have him look at it. 800-989-4909
GE MAC 5000 with a printer problem
You are probally using the wrong paper. Look at the part number for the paper you are using and cross refrence that with the correct number.
ECG PAPER DOES NOT ADVANCE
Hello fbadin1, contact Marquette/GE with model # of unit and order the paper drive assembly. Been there do that. Merry Christmas.
