20 Most Recent Tally Line Matrix T6100 Printer Questions & Answers
T6100 firmware update
You have T61100 Printer firmware???
5/29/2014 8:09:35 AM • Tally Line... • Answered on May 29, 2014
T6100 firmware
Send mail to [email protected] i wl send youT6100 Firmware
5/29/2014 7:57:37 AM • Tally Line... • Answered on May 29, 2014
0answers
Platen open
Be the first to answer 4/17/2014 7:15:45 AM • Tally Line... • Posted on Apr 17, 2014Be the first to answer
2answers
Tally T6100
i need printer driver. kindly send me very much urgentaly.
thank you!
11/14/2013 2:54:17 PM • Tally Line... • Answered on Nov 14, 2013
0answers
Error message setup to address the power of the printer
If there is a message on LCD display to "SET THE ADDRESS" the printer will be fitted with a CO AX/Twin Ax InterfacePress CLEAR to CLEAR the error, then enter the menus on the printer and set an address for the Co-Ax/Twin Ax interface, if you are using this the address would need to match the system set up. If you are not using Co-Ax/Twin Ax set a random address to clear the error. Perhaps consider removing the interface if you are not using it
4/23/2013 1:13:52 AM • Tally Line... • Answered on Apr 23, 2013
2answers
Blk 0 chksum error
fault "blk 0 chksum error" is attributable to a corrupt firmware. Fortunately the firmware can be reloaded and restore the printer in operating condition. You can download a firmware from the tallygenicom.com site under support and drivers then download it in your PC. Normally you need to put the printer is flash download mode also instruction can be seen from the site. If you cannot do this I can assist you with this.
3/19/2013 8:58:21 PM • Tally Line... • Answered on Mar 19, 2013
Self test error
just p m card replace and tested working fine
2/20/2013 1:03:42 PM • Tally Line... • Answered on Feb 20, 2013
0answers
0answers
2answers
My system is Vista. The Lipi Printer Driver is not
What is the Lipi printer model you are using, for most of the Lipi printers, the Drivers are inbuilt in Vista Database.
8/16/2012 4:25:03 PM • Tally Line... • Answered on Aug 16, 2012
0answers
0answers
Error badint 0085ddc0
The 'badint' error on the T6100 indicates the printers firmware has for some reason 'crashed', this error should not be seen in normal operation of the printer.One common cause of "BADINT" messages is the use of an external print server or host computer with incompatible parallel-port settings. If you have an external print server connected to the printer's parallel port there is a setting on the print parallel interface that may need changing, to change parallel interface setting. • Set the printer to Offline. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On) • Press the Mode key: display will show Offline Normal. • Press any Arrow key until display shows Offline Config. • Press the Forms/1 key. • Press any Arrow key until display shows Config Paralel. • Press the CPI/2 key. • Press any Arrow key until display shows Paralel Bi-Dir. • Press the LPI/3 key. • Press any Arrow key until display shows Bi-Dir Off. • Press the Enter key and the interface will be set. • Press the Clear key. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off) On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
12/16/2011 12:51:00 AM • Tally Line... • Answered on Dec 16, 2011
Printer is not able to
Use the free Adobe Reader software to "open" the PDF file.
Then, use 'File' and 'Print' and select the Tally Printer.
8/26/2011 6:19:06 AM • Tally Line... • Answered on Aug 26, 2011
Tally Line Matrix T6100 Printer Logo
56 questions posted
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
rectifity paper motion flt problem
  • Office Equipment & Supplies
