20 Most Recent
Porter Cable 60096 Rebuild Kit Rn175a Roofing Nailer Questions & Answers
Coil nailer
Make sure that the check band (black rubber band) is installed around a series of holes drilled into the lower part of the cylinder. This band can fall out of place when installing the cylinder ring. Good luck
Porter cable air nailer leaking
It certainly sounds like you may need to replace the seals on the tool.
The two main culprits are loose screws or bad seals.
Try tightening all the screws on the unit.
If that doesnt fix then you will need to purchase an overhaul kit for your model or take to a repair shop.
Since you did not give me your model #, Here is link to locate necessary parts:
http://servicenet.deltaportercable.com/Thanks
Is a porter cable fr350 the same as fr350a?
The fr350a is completely different from fr350. The fr350a is completely modernized framing gun as compared to the retired version. I do not like repair kits because you are replacing parts that are still good. Instead replace parts as needed. If you state the issue you are having I may be able to recommend the actual part needed. If however you do not have any major air leaks, a lube job will make the gun work great. Use white grease or nail gun oil. Good luck with your repair.
Porter Cable Brad Nailer - Firing without pressure
The nose tip is most likely stuck in the ready to fire position from too much force being applied when nailing. These guns are small and sensitive to forces being applied. Try bumping it to see if the nose tip is retracting and compressing with each bump. Unplug and unload the gun before trying to pull the tip of the nose to retract if it is stuck. Check for foreign objects obstructing the trigger and safety mechanism
