20 Most Recent
Snapper 217020b Lawn Mower Mowers Lawnmower Questions & Answers
My snapper hi-vac niwer us
If you are having problems starting your mower you shouldcheck 3 things, air, fuel and spark.
Fuel: check to make sure you are full of good quality fuel, try to start theengine several times then take out the spark plug and it should look wet. If its not wet then you aren't getting fuel into the engine.
Air: remove and clean the air filter with clean gasoline if its made offoam. If its made of paper then you should buy a new one from a localauto parts or hardware store.
Spark: disconnect the spark plug wire from the spark plug and hold thewire close to the engine block. Try to start the engine and watch for aspark to jump between the end of the wire and the engine block. If itdoesn't then either the wire is bad or the ignition coil is bad.
In the middle of mowing it just shuts down. There
Hi nancysalvato...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
200z snapper mower blades only engage when deck height button in pressed
My first impression is a ground issue. You might try disconnecting the deck height switch and see if/how the symptoms change.
The wiring diagram shows the electric clutch is energized when the ignition switch is in either run or start with PTO switch on. Testing can be done without the engine running. Check the common ground point.
Looking for brake kill switch on snapper
https://www.insidetheyard.com/how-to-bypass-safety-switches-on-snapper-riding-mower/#:~:text=There%20is%20another%20type%20of%20safety%20switch%20on,your%20snapper%20riding%20mower%20near%20the%20pedal%20area.
Snapper LT cranks but won't run
check the gap between the magneto and the magnet in the flywheel You may need to look up the model number of the engine but the specs are out there.
