20 Most Recent Olympus VN-240 Digital Voice Recorder Questions & Answers
You can use Digital Media Recovery Utility to retrieve your deleted data. This software supports all versions of Windows like Windows 8, 7, Vista, XP, 98, 2003, 2000 and 2008 Server. I'm use this software and I am happy because this software too good. For more details: http://www.digitalphoto.freedatarecoverysoftware.org/
Olympus VN-240... | Answered on Jan 09, 2017
I am sorry here that. And generally, voice reorder save files in the internal hard drive or the external memory card, so you can try to recover the voice files as a hard drive files, know more here Audio Recovery
Olympus VN-240... | Answered on Apr 05, 2014
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in all the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again. Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
Olympus VN-240... | Answered on Oct 14, 2012
You may download a copy of the manual here.
Olympus VN-240... | Answered on Mar 06, 2012
How can I solve the problem when it record only for 60 seconds
Olympus VN-240... | Answered on Jul 21, 2011
Any available updates will be at www.olympusamerica.com .
Olympus VN-240... | Answered on Sep 07, 2010
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Olympus VN-240... | Answered on Aug 17, 2009
Digital Wave Player (2.0):
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Olympus VN-240... | Answered on Jul 28, 2009
This is because this device will never be compatible with a 64 bit VISTA OS. Olympus now has a VN-3200PC or VN-5200PC that are compatible with the 64 bit VISTA OS platform.
Olympus VN-240... | Answered on May 07, 2009
Did you turn HOLD off (on the side)?
Olympus VN-240... | Answered on Apr 24, 2009
I have the same unit that is not working at this time, but if I remember correctly try this: Once the "yes" comes up to erase, hit the erase button again. If that doesn't work, press in the center of the large round button. Hope this works for you, if not download instructions from website.
Olympus VN-240... | Answered on Apr 06, 2009
Olympus VN-240 Digital Voice Recorder Logo
Popular Tags
39 questions posted
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
find download software olympus digital
  • Audio Players & Recorders
