20 Most Recent MGE UPS Galaxy 3000 UPS System Questions & Answers
Cc board and ch board fault
This is a repeat question
3/9/2022 9:32:37 PM • MGE UPS Galaxy... • Answered on Mar 09, 2022
Ups mge galaxy 3000 G3K
If you cannot do a reset of the internal fuse system and get it operational, then check the internal battery for continuity. If they all fail, then the AC/DC transformer has blowen.
3/9/2022 9:31:45 PM • MGE UPS Galaxy... • Answered on Mar 09, 2022
Cc board and ch board falut
Invalid question
3/9/2022 9:30:38 PM • MGE UPS Galaxy... • Answered on Mar 09, 2022
2answers
Mge 3500 service manual
do the training with Schneider electric and you will get it
3/9/2022 9:28:01 PM • MGE UPS Galaxy... • Answered on Mar 09, 2022
2answers
Mge galaxy 3000 how to
Unfortunately the reset is only possible with MGE software (Softunor).
3/9/2022 9:23:56 PM • MGE UPS Galaxy... • Answered on Mar 09, 2022
WHAT IS THE BEST TYPE
Please DON'T CRY !
2/4/2018 10:20:01 AM • MGE UPS Galaxy... • Answered on Feb 04, 2018
Galaxy 3000 ups battery breaker will not reset
check battery s for bulging or cracks--- replace if not normal not resetting indicates a battery /power supply problem
9/20/2016 9:50:00 AM • MGE UPS Galaxy... • Answered on Sep 20, 2016
2answers
When i want to boot my ups, it will try to boot
add some cooling liquid . water and alcohol
6/4/2015 12:07:15 AM • MGE UPS Galaxy... • Answered on Jun 04, 2015
Galexy s3 keeps droping calls, turning volume and brightness off
can you explain the problem with a bit more detail?
5/19/2015 6:03:11 AM • MGE UPS Galaxy... • Answered on May 19, 2015
3000 default galaxy password
0 0 0 0 or 9 9 9 9
2/2/2015 12:32:50 PM • MGE UPS Galaxy... • Answered on Feb 02, 2015
Displays error 4-2-6
it means emergency power off activated on the charger and battery fault must be checked
2/2/2015 12:12:02 PM • MGE UPS Galaxy... • Answered on Feb 02, 2015
Service manual
you need training on the product, check Schneider electric web site
2/2/2015 11:01:49 AM • MGE UPS Galaxy... • Answered on Feb 02, 2015
Mge 3000 bypass problem
what is the question? would you explain more to enable me helping you.
2/2/2015 10:54:12 AM • MGE UPS Galaxy... • Answered on Feb 02, 2015
Red yellow orange lights
red is an alarm orange/yellow is a warning
2/2/2015 10:52:47 AM • MGE UPS Galaxy... • Answered on Feb 02, 2015
NO VOLTAGE ON YELLOW PHASE
why don't you check the output fuses of the UPS if are ok than fix or replace the power module.
2/2/2015 10:21:44 AM • MGE UPS Galaxy... • Answered on Feb 02, 2015
2answers
On our 20kVa unit we got a 'battery must be
The internal automatic battery test is picking up some differences between the actual value of the battery to the mathematical calculation used in the software. Normally if you do a battery impedance test you would find that the batteries would be consistent and therefore replacing the batteries may not be the solution. Once you transfer the UPS on BYPASS and then recycle the power you would clear the alarm. However on the next internal automatic battery you would be getting the same alarm again.
At times this may be a software issue or an SNMP problem. Normally to refresh the battery data for the UPS monitoring software we carry out a battery discharge test. Please consult with the supplier if an annually battery discharge test is mandatory for the battery monitoring circuit to work well. Please let me know of the outcome
1/2/2015 7:44:10 AM • MGE UPS Galaxy... • Answered on Jan 02, 2015
2answers
what caused the UPS to transfer to Bypass? could be inverter fault, would you please check your battery set, maybe the input power is outside the tolerance and causing UPS to discharge the battery set , as well when battery set reaches the end of discharge it is causing the UPS to transfer to bypass and there is something missing on the input yellow Phase. if the above is not true check the load type that is connected to the UPS output that is causing UPS to switch off in 10 minutes time.
5/12/2014 4:25:22 AM • MGE UPS Galaxy... • Answered on May 12, 2014
MGE UPS Galaxy 3000 UPS System Logo
64 questions posted
Top MGE Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MGE Computers & Internet
Most Popular Question
galaxy 3000 ups battery breaker will not
  • Computers & Internet
