20 Most Recent Timex 20031 Wrist Watch Questions & Answers
Thanks for contacting FixYa.
This link should give you the directions you are looking for:
http://www.speidel.com/default.cfm/PID=1.24?PID=1.24&inq_key=7851&action=detail&LibID=465
Best wishes. Jewel
Timex 20031... | Answered on Oct 05, 2010
Battery issue is my best guess, have it changed!
Timex Watches | Answered on Oct 06, 2019
Google shows how.
https://www.leaf.tv/articles/how-to-set-the-date-for-a-timex-expedition-indiglo-watch/
?Quoting from the link above:
?"The Timex Expedition Indiglo wristwatch tells the time and date, illuminates at the press of a button, and can wake you up at a designated time. Once you receive and adjust your watch to your liking, you might have questions about how to program the date properly. You’ll want to have an accurate watch before wearing and relying on it throughout your day in class, at work or while exercising. You can set the date on your watch with a few simple steps.
Pull the plastic guard from beneath the crown knob (located on the right edge of the watch), and push the crown knob into the watch to start your watch. You will see the second hand begin to advance.
Pull the crown knob out to the middle position to set the day. The crown knob has three positions: “In,” “Middle” and “Out.” Turn the crown knob clockwise to advance the days up, until the current day appears in the window on the right side of the watch face. Turn the knob counterclockwise to move the date down in number. Push the crown knob all the way in to start the watch.
Pull the crown knob completely out, if the day doesn’t change with the knob in the middle position, and cycle the time backward or forward through 24-hour periods until you arrive at the current day. Push the knob in to start the watch.
Pull the crown out to the middle position and adjust your date to the next month for months that have less than 30 days. Your watch will cycle through 31 days every month, so manual adjustments for shorter months are required."
Timex Watches | Answered on Sep 27, 2019
What would do is take it to a Walmart watch department they have batteries and can help you open the back. Assuming you can't open it
Timex Watches | Answered on Sep 08, 2019
Setting The Alarm Time
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the POWER/MODE button until the display briefly shows 'OFF'
and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the TUN + (HOUR) button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is 'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the TUN - (MINS) button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM1 button once more to confirm the wake-up time setting or after 8 seconds the display will stop flashing and the new wake-up time will be entered automatically. The display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. The Buzzer indicator will turn on. Press the ALM1 button once more to select the Radio alarm. The Radio indicator turns on. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
https://cdn.timexaudio.com/media/product/files/T235_User_Manual.pdf
Timex Watches | Answered on Aug 14, 2019
I wouldn't exactly call one minute per week fast, but it can be annoying to have to keep setting it. It could be your own chemistry that is causing this. It happens to some people.
Is it a wind up?
Timex Watches | Answered on Jul 17, 2019
When you go through the set up you will see 12:00 flashing. Push the set button again and you will see 24:00 flashing, select this and move on and should be good
Gabe Barrow, Barrow's Jewelers
Timex Watches | Answered on May 28, 2019
i don't know. dollar stores may sell watch bands. watch
retailer may charge to resize your band. store where you purchased it may have tools for easy fix at no charge. just take proof of purchase and watch.
Timex Watches | Answered on May 21, 2019
Timex 20031 Wrist Watch Logo
1 questions posted
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
MrFixitSTTL
pacdave
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
just bought ladys digital
  • Watches
