20 Most Recent
ATI Asus P4R800-V Deluxe Radeon FSB800 Prescott Ready Motherboard (MOTAS30) Questions & Answers
I hv lost my motherboard
Sir,
Here is the link you need for all the drivers and manuals for that motherboard. Just choose your operating system and it will take you to your drivers.
ASUSI hope this helps,
Eric
1/22/2009 9:12:26 PM •
ATI Asus...
Answered
on Jan 22, 2009
No signal to monitor.......all dark
and im sure the screen appers to be blank and the key board lights flash once and no feed back other than the fans spinning right? . this is a common problem with asus motherboards and AMD cpu's which indicates a bad motherboard or cpu if you have acces to anouther cpu try changing to that one if that doesnt work you're motherboard is gone
thank you
ace
12/11/2007 6:35:50 PM •
ATI Asus...
Answered
on Dec 11, 2007
My HD 4850 fan is
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
My graphics card will not
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
HIS radeon HD 6750
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0?
PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.The last possibility is that there are power issues. A couple of possibilities:
- An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
- Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
- You got a bad card, or else it shorted out, etc. during setup or installation.
Gigabyte vga card d33006
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
