20 Most Recent
Onkyo TX-DS555 Receiver Questions & Answers
No Power
The standby light is on, indicating CPU is now working.
but receiver doesn't power up -- either by switch on front or by remote. There is no display & no operational mode is functioning. This means the power on relay RL901 isn't ON, perhaps. Follow these steps:
(1)download TX DS555 service manual
(2)Unplug the amp
(3)open the amp cover(4)check the AC inlet board, PS6303
(5)see P.31 B(vert.)D(horizon.)(6)Check R922, R923 ,Q921 ,C922, RL901 and a T-fuse,thermal fuse, located at the primary side of the large transformer, ETC-6304.
My a/v receiver gets really hot after a couple
You are going to make the system overheat and possibly fail with excessive heat. If it's possible, at least run with the doors to your cabinet open and/or, maybe you could cut a hole in the back of the cabinet for ventilation either just by making a hole(s) and/or installing a fan. The circuit boards will afil over time, with age but, you will greatly age your unit with excessive heat.
Want to purchase a blue
All of them will work just fine audio-wise with the Onkyo and on some level just about any TV made in the last 20 years if it has s-video, composite video, component video or HDMI video inputs (google them).
Choose one and follow the manuals for connection.
Here's yours...
http://www.retrevo.com/support/Onkyo-TX-DS555-Receivers-manual/id/365dj180/t/2/
Keep in mind that no video must necessarily pass from the the BluRay to the receiver but it MUST find its way to the TV. It's best to have any audio or video signal go directly to the best electronics that handles it. That's one reason they can be routed separately.
