20 Most Recent
Fisher Price Fisher Fun 2 Learn Computer Questions & Answers
I no longer have the original Computer Cool School
If you don't have the software on a backup disk you made from your previous system, try going to the Fisher-Price website, look for 'Support' and you may be able to find a download of the missing disk there.
Buttons on computer cool school keyboard not
Hello sir/ma'am good day, you seem to have trouble with your FPC keyboard, like any other keyboard they will eventually fail, they get dirty inside, or due to abuse of use, but are repairable. keyboard usually have access screws under, you have to remove each one to open the back plate. be careful cause there are little pieces of rubbers, springs and button that you may loose during the opening of the lid, locate the trouble button and clean the contact plate, you may use clean cloth or contact cleaner solution, not alcohol. after you are done reassemble the keyboard. test. hope this helps, if ever you need more assisstance feel free to ask. thanks
How do I fix the Fisher price merry go round? And put it back together? The mechanism was made in Switzerland
How to assemble:
Steps:
Mechanism casing upside down:
- insert man
- insert on/off switch
- insert small cover
- insert small gear
- insert H shaped part at the gear opening
- align base and screws in w 2 screws
Right side up:
- attach big gear and axel to small gear inside casing
- place scoring under axel and onto the base
- align merri go round against mechanism and 2 screws
Upside down:
- screws 3 more screws of merry go round piece
Switch from French back to English
Check inside where the batteries are stored. There may be a switch that changes the language and it might have gotten jostled and switched on its own. If still no luck, remove and replace batteries to see if it resets. If that doesn't work contact Fisher Price customer service for more assistance. Bonne Chance! (That's Good Luck in French) If you haven't fixed your toy yet, you might already know that. =) Au Revoir
How to open FP music box record player, #995 or #995N
Fisher Price Music box: to open, remove the four screws from the bottom, open the two parts as wide as possible without using too much force. Using a small flat blade screw driver, insert between the red cover and white top where the wind up knob is located. Pry the red bottom out far enough to allow the ring surrounding the knob to slide under the red bottom. The box is now open.
After repair, and re-assembling, make sure the wider part of the wind up stop wheel faces the front of the player, otherwise the wind up knob catches and slows the mechanism.
