20 Most Recent
Furuno FCV 295 104" Fish Finder Questions & Answers
Screen problem
The sun screen coating is damaged. This usually happens when salt water is allowed to dry on the display face or cleaning chemicals are used. The bezel will need to be replaced. 001-036-750 $115
I have a furuno FCV295
If you reset it and while in the Initial Settings" Menu, you press menu, it should take you to the transducer setup screen. These menus allow for "Transducer Type" to be changed to your exact transducer. See the "Installation Manual", which is different than the "Operators Manual". Section 3 page 9 and 10. You may have to enter your units of measure (Knots vs MPH, etc), and then it will allow you to choose the transducer type. Hope this helps. John Barry, 847-746-0100, technicalmarine.com.
How to program frequency 8113.5 on my Furuno FSS1503 Single Sideband Radio Telephone?
To program a specific frequency on the Furuno FSS1503 Single Sideband Radio Telephone, you can follow these steps:
- Press the Power button to turn on the radio.
- Press the Frequency button to select the desired frequency range (HF, MF, or VHF).
- Use the arrow keys to select the desired frequency (8113.5 kHz in this case).
- Press the Enter button to confirm the frequency selection.
If the frequency is not working, there may be other factors affecting the radio's performance, such as interference, atmospheric conditions, or a faulty antenna. It is recommended to use an antenna coupler or tuner to optimize the radio's performance and ensure proper transmission and reception. If you are still experiencing issues, you may need to consult a professional technician or the manufacturer's customer support for further assistance.
I need service manual book furuno fcv 620
The user manual is easy to find but they post warnings if you try to open it up and state you should contact an authorized repair facility or the factory. I could not find one.
