20 Most Recent
JBL Mbb319 SiriusReady AmFm Receiver Questions & Answers
Jbl mb3319 siruis ready stereo wont play
A Subwoofer is very simple piece of electronics. Check all of your connections and your receiver's surround modes. You shouldn't need the manual to do a preliminary check on this. There might also be a problem with the subwoofer output on the receiver. Also use a tester to see if there is current on the wires coming out from the receiver. Try it with just one sub-woofer at a time and see what happens. You may not have the power to run them all or you may have a short on one. Also check the condition of the speakers themselves. Rats can eat into the speakers themselves and like to chew away at the wires. Weather exposure can also dry and crack the rubber in the speakers.
My son and his buddy recently installed an
If a boat is anything like a car, the amp's negative post should not be connected to the battery, but to the ground of the boat. In a car, the entire chassis is grounded to the negative terminal, so when you run a line from the positive terminal of the battery to the positive post on the amp, and a line from the negative post on the amp to the chassis it is a complete circuit. I highly recommend placing a fuse on the positive line from the battery to the amp. Wiring this way prevents the amp from blowing up your battery, as well as prevents the battery from blowing your amp. Hope it works.
5/14/2012 10:31:21 PM •
JBL Boating
Answered
on May 14, 2012
