20 Most Recent Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC) Questions & Answers
I have a Sony Snaplab up-cr10l and it says on
I'm sorry. Only working with genuine consumables, others don't give good results in color or machine care.
11/21/2013 4:35:02 PM • Evolis Pebble 3... • Answered on Nov 21, 2013
3answers
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
7/25/2013 12:04:42 PM • Evolis Pebble 3... • Answered on Jul 25, 2013
2answers
Frequently, when printing a card, the ribbon gets
According to your problem, first check that you have put the card in the printer properly. These types of printers are very sensitive. It can make malfunction for a little wrong with card or also with bad quality card or printer.
Check the ribbon quality or change the ribbons which are not in good condition. Re prepare those ribbons in cartridge and then install the cartridge properly. Check the printer settings also and reboot it. Try this it will help you.
9/30/2011 3:21:56 AM • Evolis Pebble 3... • Answered on Sep 30, 2011
Mi evolis peble 3 dejo de funcionar, que hago?
english please
6/7/2011 7:40:42 AM • Evolis Pebble 3... • Answered on Jun 07, 2011
Evolis pebble 3 is printing very dark
Check for luminosity and contrat settings in properties/graphic/more options
If you have replaced print head enter its serial number properly.
4/27/2011 9:35:42 AM • Evolis Pebble 3... • Answered on Apr 27, 2011
I have problem with my Evolis Dualys 3 printer
Your print head needs to be replaced if it a horizontal line
. Transport belt to be replaced if vertical line
4/27/2011 9:34:44 AM • Evolis Pebble 3... • Answered on Apr 27, 2011
I am trying to reinstall my evolis pebble 4
Manually delete all the files related to driver from windows/system32 folder subfolders and then restart.
4/27/2011 9:33:54 AM • Evolis Pebble 3... • Answered on Apr 27, 2011
At the moment blank cards
You may try cleaning all Rollers including feeder roller.
To move rollers just remove ribbon , feeder and press front panel button and keep it pressed with top cover open . All Rollers will start moving and you can clean them easily using cleaning kit.
Also check for thickness adjustment pointer.
4/13/2011 6:09:13 AM • Evolis Pebble 3... • Answered on Apr 13, 2011
Cant download the driver from
May be problem with connection . You can give me your mail id and printer model I will send you driver
My id
[email protected]
4/13/2011 6:03:17 AM • Evolis Pebble 3... • Answered on Apr 13, 2011
Fault light showing hand is
It means you need to insert a cleaning card for cleaning cycle of printer.
Open printer properties Click on Tools tab click on Printer self cleaning button. You will get a new dialog box asking to remove ribbon and cards and insert a cleaning card in feeder.
Insert a cleaning card in feeder . Adjust thickness pointer to maximum remove ribbon and just cleck to proceed for cleaning.
4/13/2011 6:02:07 AM • Evolis Pebble 3... • Answered on Apr 13, 2011
Everytime I print, the ribbon gets stuck to the
check the sensitivity in your printer properties. It must be too high that's why it burns your ribbon.
11/8/2010 1:04:29 AM • Evolis Pebble 3... • Answered on Nov 08, 2010
Evolis Pebble 3 printer: the varnish is being put on as black
Check if ribbon type is proper.
Do self adjustment at once.
Clean optical sensors emitting blue light just below you install ribbon in printer
10/18/2010 12:53:48 PM • Evolis Pebble 3... • Answered on Oct 18, 2010
Patchy printing
Problem is with either with cards or with print head's mechanical alignment. Try with some different cards and for head get it tested by some authorised service person.
3/23/2010 10:34:37 AM • Evolis Pebble 3... • Answered on Mar 23, 2010
Fading image...
1.Check for proper driver on evolis site.
2.Check whether both side printing is selected in driver
3.Check for Varnish sensitivity setting in Graphics setting it should be default.
4.Read the ribbon type with Rr command.
3/23/2010 10:31:52 AM • Evolis Pebble 3... • Answered on Mar 23, 2010
On varnish the printing is break on 50% and stop?
You must check for
1. Varnish Sensitivity in Properties\Graphics tab it must not be too high
2. Check for steel plate on print hed if its alignment is proper or not
3/23/2010 10:29:14 AM • Evolis Pebble 3... • Answered on Mar 23, 2010
Evolis pebble 3 displays mechanical problem error?
Clean all rollers
Check if print head is mounted properly
8/29/2009 11:05:29 AM • Evolis Pebble 3... • Answered on Aug 29, 2009
My Evolis Pebble 3 says feeder error but there is
You must take following approach
1. There is a lever at feeder for thickness adjustment . Check it for proper thickness.
2. There is a hanging lever which acts as a card presence detector just where you place cards check if it is stuck and try to clean sensors aside it by blowing air .
3.Check if feeder motor is working by giving Mf;+ command
4.Check for proper ribbon setting.
5. Try downloading firmware which is available as an exe file for different models on Evolis site.
6. diagnostic software is also available on site.
7. You can also do self adjustment to adjust sensors.
8/29/2009 11:02:56 AM • Evolis Pebble 3... • Answered on Aug 29, 2009
Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC) Logo
31 questions posted
Top Evolis Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
k24674
DG92
DG92
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Pebble Evolis
  • Pebble Evolis
Most Popular Question
everytime print ribbon gets stuck
  • Office Equipment & Supplies
