20 Most Recent
Radio Shack TRC300 Voice Recorder Questions & Answers
I did not convert my files into the wav format and
The RadioShack 43-127 Digital Voice Recorder records in .wav format.. You don't have to convert anything. It records, saves, and transfers what it records as .wav files.
RadioShack Digital Voice Recorder 43 127 Records Telephone Conversations
Unfortunately, when hard drives crash, data stored on them is often lost due to corruption to the magnetic surface of the discs themselves, or to actual physical damage. If no .wav files are able to be seen, they may have simply been lost.
If those files still exist and are able to be retrieved from the disc surface, they will be in the same location within the directory structure that you originally saved them to.
PLEASE I WANT THE LATEST
I got it to work. First, I downloaded the software from the Radio Shack site at:
http://www.radioshack.com/graphics/uc/rsk/Support/SoftwareDownload/4300127.exeOnce downloaded, I ran this to extract the files to my hard drive under c:\4300127.Next I went to my Device Manager (My computer->Manage->Device Manager) and under Other Devices found my 43-127 recorder. I right-clicked on this and selected properties. Then I clicked Update Driver. I then selected "Browse my computer for driver software". I then selected the C:\43-127 directory and selected ok. I got a warning about not finding the publisher but I opted to install the driver software anyway.One other thing I noted; When I start the recorder software I have to select "Run as administrator" otherwise the files aren't able to download to my hard drive. This may be just due to a security setting on my computer.Hope this helps!
Can you please fix my
Use the driver for Vista (either 32 o4r 64 bit depending on your Vista version) - it is provided in the 43-127 software.
Optimus lab 1100. Huge distortion. I place my finger on the arm and all is good. Any idea ?
it is not a computer or PC so moved YAH/
it is home stereo sound turntable .from RADIO SHACK.
that that is easy seen it vast times back in the 60s.
- the pickup cartridge the needle there is packed in lint clean it .
- if not that , the tracking pressure is set wrong, RTM.
- if not that the tracking arm is binding find where and correct that.
- the needle is bad. (or its cartridge.
the manuals says, not adjustable, making this turntable junk class.
Ive owned many and this is junk.
that failures is pure mechanics, only.
here is mine, a real TT (note the brand)
https://imboldn.com/technics-sl-1200g-direct-drive-turntable/
note tracking controls full .
after a new cartridge upgrade that ways less it must be re calibrated for pressure and tracking. or fails.
PA Amplifier blows fuses
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
