20 Most Recent Dell 4310WX Projector Questions & Answers
Turn off on screen message
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2 Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3 Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4 Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5 Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
11/15/2013 9:56:20 PM • Dell 4310WX... • Answered on Nov 15, 2013
Looking for a colour wheel for dell 4310wx - where can I get it from
HelloGet into this site. it will lead you the place to from it can be bought.http://www.biztrademarket.com/transfer_Projector-Color-Wheel-for-DELL-MP3300-MP2300_539375.htm
12/22/2011 12:46:37 PM • Dell 4310WX... • Answered on Dec 22, 2011
New configuration of controller TDS OCE 450 printer / scanner
Visit Oc? TDS450 downloads, drivers, manuals, software, firmware and safety documents (cpp.canon) Select driver then select operating system windows 10 and download the driver
9/14/2023 2:14:23 PM • Dell Office... • Answered on Sep 14, 2023
My Dell 1700 Power Supply seems faulty due to the short circuit and witness smoke coming out of the printer, how to fix this problem?
They aren't worth fixing. You can find comparable to dell's for half of the price. They are everywhere. Just make certain it is for dell 1700.
9/16/2022 11:03:51 PM • Dell Office... • Answered on Sep 16, 2022
What is the best way Fix Dell Printer Error Code 009-654?
It is an error code that is a common technical error that manifests due to poor quality prints and smudged color. It generally indicates that the printer firmware is outdated or the CTD sensor is not clean.Jan 27, 2021
Steps to Fix Dell Printer Error 009-654 - Tech Support Expert
https://techsupportexpert.com > Blog
Solved: DELL C1760NW ERROR CODE 009-654 - Printers
https://www.dell.com > community > Printers > td-p Thank you for reaching out to us. The error code shows that there is an issue with the printer ADC sensor. If you have already restarted printer multiple times ...
4/5/2022 9:00:59 PM • Dell Office... • Answered on Apr 05, 2022
How to setup DELL 3130 cn color laser printer
google dell 3130cn manual for more info https://downloads.dell.com/manuals/all-products/esuprt_printers_main/esuprt_printers/dell-3130cn_user%27s%20guide_en-us.pdf
2/14/2022 1:41:07 AM • Dell Office... • Answered on Feb 14, 2022
2answers
Dell 1350cnw printer paper jam
Not sure if this will help, but I resolved mine in the end by opening the toner compartment and removing all of them then popping them back in. I also 'scrubbed' some sensors via a blue pullout bar in the toner area.When I started up the printer, I then held down the Red X button until it said 'ready to print'. It's working fine now.HTH,Tony
2/9/2022 4:42:58 AM • Dell Office... • Answered on Feb 09, 2022
Hi, I am having this error code: 2080000. Our Dell Printer model number is E525W.
ask dell what might be the cause
2/9/2022 1:35:47 AM • Dell Office... • Answered on Feb 09, 2022
I have a Dell W5300 printer. After removing all
Have you attempted leaving the printer unplugged (if possible in the on position) for a period of 5-10 Minutes?
2/9/2022 12:36:51 AM • Dell Office... • Answered on Feb 09, 2022
Paper jam error 234.01
paper jam 234.01 lexmark x364 dn am not able to see the jammed papers how to remove them urgent
2/2/2022 3:16:49 AM • Dell Office... • Answered on Feb 02, 2022
Is a Dell V313 Printer WiFi capable?
all printers made , modern this is and was an option new 313 was an option, 2009 old printer it is, the manual tells how to use that, here if it is present. did you used USB before not told. and if yes or the seller did used and you bought printer the printer must be reset;. page 21 https://www.manualslib.com/manual/227801/Dell-V313.html?page=21&term=reset&selected=1#manual or is this a pre buy question, if yes ask them. can can not ESP THEM NOR PRINTER OPTIONS EVER. non deities we are page 55 is wireless setups. The printer supports three wireless security options: no security, WEP, and WPA/WPA2 wpa2 is the best, others are super un-secure. page 88 wifi trouble shooting is there. if printer is used, (bought) page 89 must be reset
12/31/2021 5:01:11 PM • Dell Office... • Answered on Dec 31, 2021
Dell 1350cnw paper jam error, paper cleared, any way to fool the paper jam sensor?
none we know of check with manufacturer
12/17/2021 7:54:39 PM • Dell Office... • Answered on Dec 17, 2021
How To Fix Dell E514dW Wireless Printer Setup?
You do not state the issue. Cannot 'fix' no issue.
3/26/2021 9:50:13 AM • Dell Office... • Answered on Mar 26, 2021
Dell 4310WX Projector Logo
6 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
turn off screen message
  • Office Equipment & Supplies
