20 Most Recent Liebherr KES4260 Refrigerator Questions & Answers
My fridge is freezing everything. I've received
Not sure if you have got this fixed, but it is highly unlikely to be the PCB. There are diagrams (via google) to show where parts are and the service manual is downloadable if you search your model.
8/18/2018 11:09:33 AM • Liebherr KES4260... • Answered on Aug 18, 2018
Lights and pump turning on and off rapidly in succession
I had this, there are two circuit boards, one on the front under the switches the second in the back near the compressor. which is really hard to reach, your guessed it, its the one near the compressor that needs replacing, its around 70 pounds stirling..
10/22/2013 9:04:10 AM • Liebherr KES4260... • Answered on Oct 22, 2013
0answers
My freezer door has been
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/17/2011 3:56:39 PM • Liebherr KES4260... • Answered on Sep 17, 2011
No ice is being made in the icemaker. The
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/10/2011 3:39:29 PM • Liebherr KES4260... • Answered on Sep 10, 2011
0answers
The refridgerator keeps beeping
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
8/8/2011 1:51:04 PM • Liebherr KES4260... • Answered on Aug 08, 2011
0answers
Icing up on fress food side? too much ice on fress
Hi If it has ice buildup on the back wall inside the freezer, it appears to have a defrost problem. Unplug it, put your food in another unit (or ice chests), open the freezer door and let it thaw out overnight for at least 12 hours or more, or until all the ice has melted from *behind* the back wall. Then close the doors and run it for 4 hours and check to see if the fresh food side is cold. If it is, call a repairman to fix the defrost problem. That could be a burned out heater, terminator, or defrost timer depending on your exact model. Thanks
2/22/2011 1:32:50 PM • Liebherr KES4260... • Answered on Feb 22, 2011
Putrid cheesy smell eminating from the back of our Fridge-Freezer
To eliminate bad smells from just about anything..place an open saucer of unused coffee grounds in the space. Coffee will stop any bad smell!
12/25/2010 6:27:53 PM • Liebherr KES4260... • Answered on Dec 25, 2010
For several days now we
hi hazel,not sure about this particular model but if you have a drain hole inside on the back, syringe out with clorine bleach(the smell will go in about 30 mins).sprinkle bicarb inside to absorb any residual niffs.
hope this works for you
geoff.
10/1/2010 9:31:51 AM • Liebherr KES4260... • Answered on Oct 01, 2010
My Kes4260 refigerator just started freezing all
YOUR DAMPER DOOR MAY HAVE STUCK OPEN. IT IS LOCATED IN THE TOP BACK CENTER OF THE FRESH FOOD SECTION.
6/12/2010 9:23:40 AM • Liebherr KES4260... • Answered on Jun 12, 2010
2answers
My fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
3/8/2010 6:08:32 PM • Liebherr KES4260... • Answered on Mar 08, 2010
Liebherr KES4260 Refrigerator Logo
32 questions posted
Top Liebherr Refrigerators Experts
ZJ Limited
ZJ Limited
Paul Carew
Daniel Blask
Daniel Blask
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
several days now
  • Refrigerators
