20 Most Recent
Singer Touch Sew 7462 Mechanical Sewing Machine Questions & Answers
How to use a twin needle
In most machines you do as follows.
Insert the second spool pin and place a spool of thread on each. Thread in usual sequence but make sure to pass one thread to the left and one to the right of the tension disc and do not allow the threads to twist together then thread needles manually.
My thread is getting caught under the plate by the
If you have an a self wind bobbin make sure the bobbin winder is all the way down and no thread caught under it, your machine should be able to cope with thick fabric, slacken the pressure on the presser foot
Mygolden singer touch and sew wont feed the
Does the feed dogs move at all?
If not soulds like a busted gear. Take the botom panel off and inspect the gears should be able to get some from a sewing dealer and replace them if your mechanical. watch a youtub video on timing a sewing machine and you will do great.
hope this helps
Need instruction how to make bobbin on Singer
Hello, eblazeI
am trying to help you out here. Maybe this will help some? I am known on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved. I do this on my own time for free. Think of me as a Specialized
Trouble Shooter.I have found out that it appears that lots of
customers appreciate my efforts and help. So, I thought I would take
some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about Sewing Machines and possibly yours, from repair to trouble shooting it.http://home.howstuffworks.com/sewing-machine.htmPlease
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help. It would make my time worth. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
My bobbin keeps popping out.
There is a small
Hi, the wick will not interfere with your tension, it is there to oil the hook shaft.
If you e-mail me at
[email protected] i will send you the instructions and
pictures on the bobbin case settings. Take special note of the retaining bracket, plate spring position and the Reverse rotation stopper. It sometimes happens that the reverse rotation stopper bends upwards, allowing the bobbin case to move underneath it. Press it slightly down to prevent this.
