20 Most Recent Husqvarna Huskystar 207 Sewing Machine Questions & Answers
Hello
Install the second spool pin.
Place the two spools on the spools pins, one on each spool pin.Make sure that the spools are spinning toward each other.
Thread as for single needle.
Thread each needle from a different spool.
Caution: Make sure that the stitch width is not wide than the twin needle maximum swing. Check that the needles will not hit the throat plate as they swing from left to right and back again on stitches with width.
Happy twin needling
Sewingirl/
Husqvarna... | Answered on Mar 20, 2017
The length has to be above zero. Insure the bobbin wind is off.
Husqvarna... | Answered on Aug 02, 2016
Hello, here is website to download manual
Viking Husqvarna Sewing Machine Manuals PDF and CD
Husqvarna... | Answered on Nov 11, 2015
try changing the needle--flat side goes to the back of the machine
check the thread take up lever & see if the thread is still on it
it's also possible that the machine is out of time & needs to serviced
Husqvarna... | Answered on Mar 30, 2015
look in your owners manual or take the machine to a Viking dealer and they will show you how to thread it.
Husqvarna... | Answered on Mar 15, 2015
see your friendly authorized Viking dealer.
Husqvarna... | Answered on Feb 09, 2015
there is not any placed for a user to oil a 207. if your machine is having problems, take it to your authorized Viking repair dealer.
This mess is commonly referred to as a bird's nest or 'birdnesting' and it's usually caused by incorrect top tension and that's often caused by the top thread not in the correct path. (For me, I occasionally forget to thread through the take-up lever.) A damaged needle can also cause birdnesting.
Husqvarna... | Answered on Feb 08, 2015
Suggest checking the user manual. Manuals can be viewed, downloaded, or printed at http://www.manuals.husqvarnaviking.com
Husqvarna... | Answered on Oct 16, 2014
Could possibly have the reverse feed checked by a professional - it is possible the machine got wet in the metal parts, and is rusted up or clogged up from too much oiling! NOT a quick easy fix
Husqvarna... | Answered on Jul 16, 2014
www.montavillasewing.com
I was able to get a manual for an older machine through these people. It's in Portland, OR, but I'm sure they would send you one.
Husqvarna... | Answered on Jun 16, 2014
HI Cynthia,
I have this video for you on how to do it. Hope it works.
Husqvarna... | Answered on May 09, 2014
try ebay
or a Husqvarna dealer
Husqvarna... | Answered on May 07, 2014
Was there a thread jam
Has it been regularly serviced and free from corrosion ?
Husqvarna... | Answered on Jan 15, 2014
Husqvarna Huskystar 207 Sewing Machine Logo
63 questions posted
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Husqvarna Sewing Machines
Most Popular Question
looking purchase bobbin case huskystar
  • Sewing Machines
