20 Most Recent
Elna 7200 Pro Computerized Sewing Machine Questions & Answers
7000
When this happened to me I was told the thread was old. Sure enough, it was old thread and now that I've replaced that old (20+ year) thread all is fine.
I MERELY WOULD LIKE TO
These computerised machines have a minimum of moving metal parts and many gears are nylon. In the manual it may tell you to brush out the rotary hook/bobbin holder area only. This is important, do it regularly to keep the bobbin area clean.However, it probably also says to have the machine serviced by an authorised technician annually. He will then lubricate internally and top up any wicks within the machine.There may be a wick in the middle of the bobbin holder, it will look like a bit of fluff down a hole. You could give this a drop of oil, along with any parts you can see where metal moves over metal, use clear high quality sewing machine oil. Perhaps every 3 months or so, but brushing out all lint is very imporant.
I have an elna 7000 idon`t know how to change the
YOu can dowload a manual for the Elna 7000 from here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
However, I'm not sure what you actually mean, do you mean how to program it to stitch out letters?
If so, the instructions for this are on page 28
Each stitch that shows up on the selector bars at the top has a number so to choose it, you just type in the appropraite number using the 0-9 keyboard, then press the "select pattern" key. The top selector bars turn so you can see the different range of stitches but the A B C D part doesnt come into actually chosing a stitch.
I have an elna 7000. The rotary hook is not
You may have a broken gear but I do not advise opening any part of a computerized machine, you will need a specialist otherwise you could blow the computer boards with static
