20 Most Recent
Brother CE5000 Computerized Sewing Machine Questions & Answers
How do I oil the machine?
With this machine YOU don't oil it. It is "factory sealed" with all the oil it's supposed to need. If things get stiff or difficult to operate you are supposed to call your nearest authorized dealer and arrange to take it in to them for servicing. Hope that helps. You can also find more information on that machine on the Brother website, under customer support.
Thread doesn't loop, it will not sew
try changing the needletry rethreading the machine top & bobbinmake sure the bobbin is not over full make sure the bobbin is turned the right way in the bobbin caseif these suggestions don't help then the sewing machine timingneeds to be checked at a sewing machine shop
Needle keeps hitting foot
have you tired changing the needle--flat side goes to the back of the machineit's also possible that the machine is out of timeor that the needle shaft is bentif you've already changed the needle & it's still hitting the foot then the machine needs to be serviced
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
