20 Most Recent Janome Magnolia 7330 Sewing Machine Questions & Answers
I can't get the bobbin to thread.
This video may help. Probably not your model, but machines tend to thread and operate similarly. How to Thread Janome Sewing Machine
2/17/2018 4:50:42 PM • Janome Magnolia... • Answered on Feb 17, 2018
Machine eats bobbin thread
computerized so could be anything tension or sewing action parts needs a service index-n3tzgjtvihckmmjcgghducoc-3-0_3.jpg
4/28/2017 10:54:57 AM • Janome Magnolia... • Answered on Apr 28, 2017
I have a Janome Magnolia 7330. How do you open it
If it is computerized, they are generally sealed so they cannot be opened by the user. There are computerized components that could easily be damaged. The manual should have instructions how to maintain your machine. AVOID using compressed air as it tends to push lint and dirt further into the machine where only a technician can clean.
4/12/2017 4:34:07 PM • Janome Magnolia... • Answered on Apr 12, 2017
3answers
Lo warning comes on when i try to sew. Waited 15 secs did not work. Cannot sew.
It sounds like a machine overload. Rather than just turning it off for a few seconds, turn it off and clear out the lint from the feed dogs and the traces. That should take sufficient time to reset and you'll avoid another overload.
10/17/2016 2:36:45 PM • Janome Magnolia... • Answered on Oct 17, 2016
Needle screw won't stay tight and needle comes out
the screw & the needle clamp may have to be replaced
10/31/2015 6:27:57 PM • Janome Magnolia... • Answered on Oct 31, 2015
When I give the presser foot power, it goes for about 5 seconds and abruptly stops with the "Lo" appearing on the electronic panel. How can I fix this?
Consult your owner's manual. The Troubleshooting section should explain the error code and suggestions for correcting it. ...
10/23/2015 5:42:34 PM • Janome Magnolia... • Answered on Oct 23, 2015
My machine stitches evenly, then squiggly top & bottom, then evenly, then squiggly. What's up?
It can be adjusted by the dealer repair shop. You should have a 1 year warranty to cover the adjustment.
3/5/2015 6:57:08 AM • Janome Magnolia... • Answered on Mar 05, 2015
Upper thread has a loose stitch once in a while
check that bottom and top threads are the same quality and as well I would change the needle as a first port of call ...good luck
9/10/2014 9:39:39 AM • Janome Magnolia... • Answered on Sep 10, 2014
Why will my presser foot not stay up.
It seems like something is loose as you already know. Take it to a dealer and they can fix it for you.
8/29/2014 5:31:38 AM • Janome Magnolia... • Answered on Aug 29, 2014
How do I adjust the bobbin?
Adjust the bobbin in what way? For what purpose?
7/21/2014 5:56:57 AM • Janome Magnolia... • Answered on Jul 21, 2014
After 2 or 3 stitches needle gets locked with balled thread
Lint and or thread has collected behind or under the bobbin. use a q-tip (cotton) and swipe out and around the bobbin and bobbin case. Use a can of air and blow out and around the bobbin area. Remove the spool thread from the machine and rethread the spool and bobbin thread in machine.
7/10/2014 7:36:47 PM • Janome Magnolia... • Answered on Jul 10, 2014
My janome magnolia was working just fine and then all of the sudden the bobbin thread keeps knotting up. i've gone over all troubleshooting, cleaned out the lint, replaced the bobbin - all to no avail
This happened to me on several occasions and finally one service tech told me not to use the needle down auto button. Instead when threading the bobbin just move the wheel toward you slowly until the thread catches.
7/8/2014 2:32:28 PM • Janome Magnolia... • Answered on Jul 08, 2014
Why magnolia not picking up bobbin thread
Despite what the instruction book tells you, do not use the auto downup button to pick up the bobbin thread. Instead pull the wheel toward you and do it manually. Many times the bobbin thread gets caught and the machine halts if that auto down button is used.
6/19/2014 3:13:52 PM • Janome Magnolia... • Answered on Jun 19, 2014
After 2 stitches needle is caught in ball of thread
More likely, you forgot to hold the bobbin and top thread ends together behind the presser foot when starting a seam. See: http://www.picturetrail.com/sfx/album/view/22521551
5/24/2014 9:58:25 PM • Janome Magnolia... • Answered on May 24, 2014
Feed dog problem
take the machine back & get another one or ask them to have the machine fixed.
4/29/2014 2:02:48 PM • Janome Magnolia... • Answered on Apr 29, 2014
0answers
Janome Magnolia 7330 Sewing Machine Logo
53 questions posted
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
janome magnolia 7330 open
  • Sewing Machines
