20 Most Recent Janome Magnolia 7318 Sewing Machine Questions & Answers
2answers
I need instruction manual for Magnolia 7318
Janome Magnolia 7318 (Sewing-Quilting Machine) user manual, guides and product documentations.http://janome.imvoi.com/sewing-quilting-machine/magnolia-7318.htmlLook under available documents and click on "Janome Magnolia 7318 User Manual".This opens the user manual in PDF format.You can save the PDF to your local computer to refer to any time without going online.
2/4/2022 12:27:00 AM • Janome Magnolia... • Answered on Feb 04, 2022
I want to take a Janome Magnolia to my sister who lives in Israel. Do I need a transformer ?
ring Janome customer relations and ask them
10/6/2017 10:04:24 AM • Janome Magnolia... • Answered on Oct 06, 2017
My stitch selector isn't working; it straight stitches regardless of the setting
Something is either hung up, disconnected, or the software is not functioning properly. Take it for service. ...
5/10/2016 6:45:52 PM • Janome Magnolia... • Answered on May 10, 2016
Problem with feed dogs
Did you drop them your self? If you did it may need a little more effort to push the button back into place. If they were down when you got the machine then they are not hooked up and the machine needs to be opened to connect them.
4/2/2014 12:14:57 PM • Janome Magnolia... • Answered on Apr 02, 2014
I have a jenome sewing
try sewingpartsonline.com
1/12/2011 4:46:49 AM • Janome Magnolia... • Answered on Jan 12, 2011
My Janome 300e screen is frozen on the info page (Main Ver.1.00-K-001Y, Slave Ver.001, DCI Ver.1.06) Can I reset it?
  1. Power Off: Turn off your machine completely. Make sure it's not just in standby mode but completely powered down.
  2. Unplug: Disconnect the power cord from the outlet. Wait for about 10-15 seconds to ensure all power is drained from the machine.
  3. Plug Back In: Reconnect the power cord to the outlet.
  4. Power On: Turn on your Janome 300e and see if the screen is responsive now.
If the issue persists even after performing a reset, there might be a more significant problem with the machine's software or hardware. In such cases, it's advisable to contact Janome customer support or a certified technician for further assistance. They may provide additional troubleshooting steps or recommend servicing the machine.
4/19/2024 2:35:47 PM • Janome Sewing... • Answered 6 hours ago
I have a Janome 550e embroidery machine and am trying to find the total stitch count on the machine. But I can't figure out how to find that and there's nothing in the instruction manual.
Page 27 of the manual refers. (by the number on the pages, not at the top), use CTRL+F and type the word 'Number'.
Instruction Book
Janome https://www.janome.com > embroidery > mc550e PDF q Stitch back key w Stitch forward key e Stitch count r Total number of stitch count. The pale blue bar in the stitch count window is the progress bar. The ... 76 pages ..
4/18/2024 12:04:55 AM • Janome Sewing... • Answered Yesterday
Janome 350E Sewing Machine. I am getting a message telling me to raise the presser foot and needle bar then turn off the machine. After doing all that the message is still there? What can I do?
Are you having any problems moving the needle bar with the hand wheel? Make sure that the presser foot is up and the needle bar is fully up. Then redo the top threading for the machine. Try unplugging the machine and blowing any loose debris out of the needle bar area. (I'd suggest compressed (canned) air or equivalent to minimize excess moisture in the electronics.) Also check if the machine gives the same message with the presser foot and needle down on restart. If the problem persists, then the issue is likely to be a faulty control board. I don't know if any sewing machine repair technicians still have spare boards. They aren't on the in stock parts at two vendors that I know. I hope this helps. Cindy Wells
2/25/2024 10:39:09 PM • Janome Sewing... • Answered on Feb 25, 2024
I need a machine user manual for a Janome JFS3532 sewing machine
I would look on the manufacturers web site; https://www.janome.com/blog/need-a-janome-manual-many-available-for-download-here/
2/17/2024 3:44:55 PM • Janome Sewing... • Answered on Feb 17, 2024
2answers
I have a Janome model 577 (I know it's old!!) and
If the top tension is on 0 I suspect the problem begins in the bobbin, make sure first of all the bobbin is turning anti clockwise in the bobbin case, when you pull the thread through the bobbin case there should be slight resistence, if it is too loose turn the screw on the bobbin case clockwise about a quarter of a turn to tighten, if it is not making muh difference you may have fluff stuck under the spring on the bobbin casem take a fine sewing needle and slide it under the spring to see if you can get any fluff out, top tension about 4 or 5
1/14/2024 4:44:50 PM • Janome Sewing... • Answered on Jan 14, 2024
2answers
Where can I find a Janome kwiknit Knitter CHJ-3 munual?
I have the Janome CHJ-3 Kwiknit Knitter and am having some problems with it. Purchased this machine some40 years ago and used it an awful lot and was always very happy with it. After storage and loaning it out, it now does not work. Needs a service I suppose which I would like to do myself. Does this machine have a sponge bar? Also I can copy the manual and send it to you - please let me know.
12/21/2023 5:50:07 AM • Janome Sewing... • Answered on Dec 21, 2023
2answers
Can I download embroidery editor from janome site instead of downloading from cd
You can download the Artistic Designer program from Janome, https://www.janome.com/products/software/ . However, it will not work unless you have purchased a license key from a dealer. For other Janome software, only updates for supported software are available: https://www.janome.com/support/general-support/software-support/ . You'll either need the program to have been installed on your computer or to put the CD in an optical disc drive. If your current computer doesn't have an optical disc drive, you can get a USB optical drive from Amazon or any other shop that has electronic/computer parts. USB DVD read/write drives are under $50 even at most shops that don't discount accessories. You may need the USB type C (M) to USB type A (female) adapter with some of the newest models (laptops and tablets). I hope this helps. Please add a comment with the name and version of your software for further assistance. If your software is no longer supported by Janome, there are some third-party embroidery editing software packages. One is https://www.embird.net/ . Cindy Wells
12/7/2023 2:55:53 AM • Janome Sewing... • Answered on Dec 07, 2023
2answers
Janome 350E suddenly stopped reading the USB
Your space is not formatted correctly to the size of the hoop. For example if the hoop is 5x7 your design has to fit within that space, and the space cannot be bigger than 5x7. Strange but true and it will fix the reboot and shut down issue.
12/6/2023 4:46:01 PM • Janome Sewing... • Answered on Dec 06, 2023
I need a manual for new home janome 1502 sewing machine?
All available Janome user manual are here https://www.janome.com/support/manuals/ However you can use this manual, it may help you. inst-book-mod-15.pdf (janome.com)
11/21/2023 12:33:27 PM • Janome Sewing... • Answered on Nov 21, 2023
I've been trying out a New Home, Janome 641 for my granddaughter. It will only sew backwards.
A new old machine for you I assume.For older mechanical only machines, reverse stitch is an exaggerated long stitch length that changes the angle and contact time of fabric to the feed dogs. Try setting stitch length to minimum and straight stitch. Check feed dog up/down is functional (if featured). It could also be the reverse linkage is simply stuck and the machine is in need of a thorough clean/lube.I looked for a manual but so far have not found. I'll append if I find.
11/12/2023 11:06:02 PM • Janome Sewing... • Answered on Nov 12, 2023
Janome 4618qC not making zigzag stitches
See troubleshooting section on page 49 of manual. It may help. *4618-QC (janome.com)
11/6/2023 2:20:17 PM • Janome Sewing... • Answered on Nov 06, 2023
Janome Magnolia 7318 Sewing Machine Logo
Popular Tags
14 questions posted
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
stitch selector isnt working straight
  • Sewing Machines
