20 Most Recent
Dualit 72024 Cordless Electric Kettle Questions & Answers
Kettle has just suddenly tripped the electricity.
This is because there is a current leakage between the live and earth terminals of the kettle.
You see, if current leaks from live path to earth, you will get an electric shock when you touch the outer metal surface (because the metal part is earthed). To protect you, the trip switch will cut off the electricity supply.
You can try drying the kettle in hot sun. This is because the current leakage is most probably due to water leaking in to the circuitry.
You can try replacing the heating element, if it is available in the store. Otherwise do not use it. That's better for your safety.
Toaster: Dualit Domus DLT44... First one side now the other.. Dead!
Question edited for clarity, added full stops as Fixya removes formatting and line breaks.
Question moved from Cars and Trucks to correct make category.
The latching is normally dependent on the element working. If you have a multimeter, test continuity of the elements. replacing them is normally not easy as domestic toaster use crimped wires direct to the elements cassette. I have a brand new one in my garage for a Black and Decker toaster with 18 crimp wire tails.
I used Dualit and Rowlett commercial toasters at my hotel in Cornwall, England, and they were easy to repair, but Domestic toasters are really a non repairable / replacement option. Ask Dualit what they think?
https://www.dualit.com/support/domus-4-slot-toaster
Dualit kettle switch is faulty. How do I get the switch out of the kettle?
you need to take the bottom off the kettkle and then you will be able to get to the back of the switch and see how its attatched and remove fasteners as needed and one end of the wires will need to be taken off. dont throw anything out until you look at the new switch because sometimes you dont get some little attatchment and then u will have the old set-up. hope it goes well. let us know how you do.
