20 Most Recent Breville BKE820XL Electric Kettle Questions & Answers
0answers
My Breville kettle does not beep anymore when the
Might not work, so don't cuss me if it doesn't, but have you tried demineralizing it? Pour it full of white vinegar, let it heat to about 160-180 and then turn it off and let it soak for a couple of hours. The vinegar will dissolve any mineral deposits on or in the heating system. Mineral deposits are the bain of electric water heating systems of all types. Drip coffee makers, 95% of the time, a premature ***** is due to mineral deposits. It also destroys house hot water heaters.
8/24/2016 8:01:18 PM • Breville... • Answered on Aug 24, 2016
0answers
Have overfilled
Be the first to answer 9/30/2014 3:16:31 AM • Breville... • Posted on Sep 30, 2014Be the first to answer
BKE820XL kettle glass came off what sealant to use?
I would crazy glue it thoroughly.
2/18/2014 5:41:00 AM • Breville... • Answered on Feb 18, 2014
0answers
0answers
The "boil/black tea" button quit
there is a 1 year warranty on this unit. In order to have it repaired you would need to contact breville at 1-866-Breville in order to have your unit repaired most likely you have an error witht the touch control and would need to send the unit in to them for the repairs to be made here is also there link that states there warranty information as well http://brevilleusasupport.com/product/bke820xl?lm_search=Breville+BKE820XL+Electric+Kettle if you have any further questions message me back Thanks Rick
6/29/2011 2:45:50 PM • Breville... • Answered on Jun 29, 2011
2answers
I have a Breville Kettle
Hi.
The switch does not get red because reach of adequate temperature is not detected. The problem is either thermostat or element. Both parts are tested using a multimeter set on Ohms to read impedance. if the part reads open, then it must be replaced.
Problem will be locating the part.
First call Breville and find out repair price and warranty status.
Here Breville USA:Breville . See also: Parts ' Breville
Here Australia:Breville
UK:Breville
If the unit is out of warranty call EReplacementParts, they sell parts and do repair. number is 866-802-6383
Here a disassembly diagram.
5/17/2011 4:08:59 PM • Breville... • Answered on May 17, 2011
0answers
I have a Breville BKE820
You might look into purchasing a silicon sealant. Get the food grade kind. This should do it. http://www.etundra.com/White_Food_Grade_Silicone_Sealant-P19204.html?utm_source=google%2Bproduct&utm_medium=organic
There's also a high temp version thats rated up to 500 deg F if you need to fix something with a higher heat rating.
2/14/2011 5:40:28 PM • Breville... • Answered on Feb 14, 2011
Breville model bmo0870 combi error code E08 microwave doesn't heat up, gives an error code half way through a minute
Error 08 is normally an issue with the magnetron or power supply. Not an easy fix. Call an appliance engineer.
3/19/2024 7:13:32 AM • Breville Kitchen... • Answered on Mar 19, 2024
Breville BKE820XL Electric Kettle Logo
Popular Tags
19 questions posted
Top Breville Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
yarik117
yarik117
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Breville Kitchen Appliances - Others
Most Popular Question
breville bke820
  • Kitchen Appliances - Others
